Hey all. TIA for any help.
Basically, I'm running short on time, and I need to make a DVD with a photo slideshow and I also need to have the original photos on the disc as well. Can that be done? I already have the slideshow made in Photostory 3 for Windows (wmv file), and all the files will be in a folder. So I can put both of these on a DVD that will play in a standard DVD player, right?
I guess the problem I'm running into is that I have no idea what the lowest common denominator will be. I know my DVD player can play .wmv files and view pics, but I don't know if others would need a fully authored DVD for their players. Can an authored DVD be made with the original files available as well?
So if you guys can help, I'd greatly appreciate it. Let me know if I should give more info.
Also, is there a preferred format b/w DVD-R and DVD+R. I don't really know which one is more compatible with commercial DVD players.
Thanks!
Results 1 to 9 of 9
photostory outputs WMV video, which should convert. It sounds like you are trying to load the photostory project file instead.
I would first google for Papa John and find his photostory profiles. You will be able to use these to output much higher quality than the default profiles. Then use these to create a WMV file that you can then load into DVD Flick.
You should then consider upgrading to photostory 3, which is a freebie download from Microsoft.Read my blog here.
DVD Photo Slideshow
By jet757f in forum Newbie / General discussionsReplies: 9Last Post: 13th Dec 2010, 13:54 -
photo slideshow advice
By bettytron in forum Authoring (DVD)Replies: 0Last Post: 20th Jun 2010, 01:17 -
Photo to DVD slideshow software
By Yaro in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2009, 08:53 -
Photo to DVD, slideshow speed
By leslieshen in forum Video ConversionReplies: 2Last Post: 29th Oct 2008, 09:51 -
Photo DVD slideshow movie
By j4mes_bond25 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2008, 06:58
