the source is PAL, 25fps, 720x576, 16:9, captured with handycam on DV tape
im convering it to wmv with WME
in one of the options i can choose between anamorphic 16:9 or dv pal 16:9
since i dont know anything about both, which should be better to use?
sorry for the stupid question
I think you just answered to yourself. Just place a pointer over your thread on anamorphic underlined and see what it say.
You should use anamorphic setting, because it will insert letterbox flag on DVD. -
well files will be for the web and played mostly on computers, so because of the many different screens they will be played on, i guess that's one more vote to go for anamorphic?
For web use, you likely don't want files at that resolution anyway. At least you typically wouldn't, just because of the file sizes.
And the best way to find what works best for you, is to simply experiment. Simply encode the first couple of minutes at various settings and see what works best.Google is your Friend -
this is the high quality version of the videos which will be in restricted area, so file size isnt priority here, but quality and usability
so i did some test, seems that anamorphic works better (more visible area) on both my screen (wide and standart)
so i guess im gonna go with that
thank you all for the help!!!
Is it possible to re-edit a non-anamorphic dvd to anamorphic?
By Beautiful Alone in forum DVD RippingReplies: 45Last Post: 22nd Sep 2011, 09:00 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 15:46 -
Anamorphic PAL 4:3 (576i) - least lossy resolution for web publication?
By Bubblevision in forum Video ConversionReplies: 1Last Post: 8th Feb 2009, 07:25 -
HDV (50i) to Pal Anamorphic (50i) problems with Avisynth (sample included)
By VooD in forum Video ConversionReplies: 15Last Post: 1st Aug 2008, 07:22 -
anamorphic or not anamorphic
By cd090580 in forum Video ConversionReplies: 3Last Post: 23rd Jun 2007, 12:48
