k, foolishly i bought a panasonic RP56 series DVD player which unfortunatly dosent support SVCD. i want to go abouts convertin an SVCD i have to VCD so i can play it. ive tried this multiplexin trick with TMPEG but with no luck, if anyone can provide me with a step by step instruction set it would be greatly appreaciated. Thank You
My DVD Info:
http://www.panasonic.ca/English/audiovideo/dvd/dvdrv32k_rv32s.htm
Look to the left under the CONVERT section.
Or to another way would be to use DVD2AVI and frameserve it into TMPG~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
umm look to the left of what? are u referin to TMPGEnc?
k , this is what i try:
1) i take the svcd .dat file and convert to .mpeg usin vcdgear
2) then i open up TMPGEnc (2.5)
3) Goto File-MPEG Tools
4) Goto to multiplex
5) Switch Type to: MPEG-1 Video CD
6) Add the file i converted (the .mpeg). When i add it, the mpeg video layer has the followin: MPEG-2 Video 480x480 29.79fps 2450kbp. and the mpeg audio layer has the followin: MPEG-1 Audio Layer-2 44100Hz 224kbps
7) then i click run. the out puttd file should have the video/audio in sync right? well its not =/ and the video is still chompy.
What am i doin wrong? -
You don't convert when multiplexing to vcd you just make some strange svcd format burnt in vcd mode and that may not work properly in many players. Are you sure that the audio source is in 44 khz also because if it is in 48 khz and multiplexing to 44(just changing the audio headers) may cause sync problems...I think
To convert to vcd format www.vcdhelp.com/mpeg2tovcd.htm -
sell your dvdplayer & buy one that you really want(ebay springs to mind). you'll take a loss(or you may not), but i'd sooner castrate myself than convert my svcd to vcd
Converting Bi-Lingual VCDs to Single Language MPEGs
By HHBear in forum Video ConversionReplies: 3Last Post: 13th Feb 2008, 22:05 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 10:38 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 09:06
