Hi,
I've just run through an encode using MeGui.
For video I used x264 HQ Slower in MKV container, set up for a 2CD encode
For audio I used the AC3 ripped from the VOB
I used MeGui VobSubber to get the idx/sub
I used MeGui MKV Muxer to mux .mkv, .ac3, .idx and .txt chapters and split @ 1CD
Now when I play in MPC I get no subtitles - the MPC navigation menu shows them as on, as does the Haali system tray icon.
I've switched on AutoLoad VSFilter in Haali options, MPC is set in ** modes for output
Any ideas...?
MKV embedded subtitles don't always load in MPC-HC
By aer in forum Software PlayingReplies: 0Last Post: 22nd Aug 2011, 18:53 -
.mkv subtitles in MPC
By andreyi in forum SubtitleReplies: 2Last Post: 22nd Dec 2009, 15:05 -
x264.exe error in Megui during encode
By glassbottomboat in forum Video ConversionReplies: 0Last Post: 6th Dec 2009, 22:55 -
MeGui HDTV TS to x264 mkv filesize problem
By thunder2008 in forum Video ConversionReplies: 0Last Post: 15th Jan 2009, 02:53 -
No subtitles when playing a .MKV file in MPC HC
By THX-UltraII in forum SubtitleReplies: 5Last Post: 21st Aug 2008, 07:08
