    May 2008
    Canada
    Using Ripti4me, I got the following error message after running DVD Shrink. I have backed up DVD's before, though once in a while it doesn't work, but it seems to be having more often. I am a newbie here, but I figure this is the appropriate forum.
    Thanks in advance for any help.
    1A25-0006-7130-1352-4239-7903
    Windows XP 5.1
    IA32
    WinAspi: -
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 11/11/2003 9:49:52 AM
    Nero API version: 6.3.0.0
    Using interface version: 6.3.1.4
    Installed in: C:\Program Files\Ahead\Nero\
    Application: ahead\Nero - Burning Rom
    Recorder: <HL-DT-ST DVDRAM GSA-4082B>Version: A207 - HA 0 TA 0 - 6.3.0.0
    Adapter driver: <atapi> HA 0
    Drive buffer : 2048kB
    Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
    Connected to MMC as unknown drive with class-nr : 1
    Drive is autodetected - recorder class: Std. MMC recorder
    === Scsi-Device-Map ===
    CdRomPeripheral : HL-DT-ST DVDRAM GSA-4082B atapi Port 0 ID 0 DMA: On
    DiskPeripheral : ST380811AS 3.AA si3112r Port 2 ID 0 DMA: Off
    DiskPeripheral : ST3320620AS 3.AA si3112r Port 2 ID 0 DMA: Off
    CdRomPeripheral : XO6115G UDL251G 1.0 a3ziua4p Port 3 ID 0 DMA: Off
    === CDRom-Device-Map ===
    HL-DT-ST DVDRAM GSA-4082 D: CDRom0
    XO6115G UDL251G F: CDRom1
    AutoRun : 1
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 83886080 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 1023MB (1048048kB)
    Free physical memory: 435MB (445584kB)
    Memory in use : 57 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    27.5.2008
    NeroAPI
    10:23:14 PM #1 Phase 112 File APIProgress.cpp, Line 250
    DVD-Video files reallocation started
    10:23:14 PM #2 Phase 114 File APIProgress.cpp, Line 250
    DVD-Video files reallocation completed (no file modified)
    10:23:14 PM #3 Phase 111 File APIProgress.cpp, Line 250
    DVD-Video files sorted
    10:23:14 PM #4 Text 0 File Reader.cpp, Line 118
    Reader running
    10:23:14 PM #5 Text 0 File Writer.cpp, Line 124
    Writer HL-DT-ST DVDRAM GSA-4082B running
    10:23:14 PM #6 ISO9660GEN -11 File geniso.cpp, Line 3882
    First writeable address = 0 (0x00000000)
    10:23:15 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3882
    10:23:15 PM #8 Text 0 File Burncd.cpp, Line 3094
    Turn on Disc-At-Once, using DVD media
    10:23:15 PM #9 Text 0 File DlgWaitCD.cpp, Line 239
    Last possible write address on media: 2295103 (510:01.28)
    Last address to be written: 2286383 (508:05.08)
    10:23:15 PM #10 Text 0 File DlgWaitCD.cpp, Line 244
    Write in overburning mode: FALSE
    10:23:15 PM #11 Text 0 File DlgWaitCD.cpp, Line 2068
    Recorder: HL-DT-ST DVDRAM GSA-4082B, Media type: DVD+R
    Disc Manufacturer ID: RITEK, Media Type ID: R03, Product revision number: 2
    Disc Application Code: 0, Extended Information Indicators: 3
    10:23:15 PM #12 Text 0 File DlgWaitCD.cpp, Line 405
    >>> Protocol of DlgWaitCD activities: <<<
    10:23:15 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 779
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (150) not provided
    original disc pos #0 + 2286384 (2286384) = #2286384/508:5.9
    relocatable, disc pos for caching/writing not required/required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286384 blocks [HL-DT-ST DVDRAM GSA-4082B]
    10:23:15 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 948
    Prepare recorder [HL-DT-ST DVDRAM GSA-4082B] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4682514432, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
    0 | lead-in | 0 | 0x00 | 0x41
    0 | 1 | 0 | 0x00 | 0x41
    0 | 1 | 1 | 0x00 | 0x41
    2286384 | lead-out | 1 | 0x00 | 0x41
    10:23:15 PM #15 Phase 24 File APIProgress.cpp, Line 250
    Caching of files started
    10:23:15 PM #16 Text 0 File Burncd.cpp, Line 4061
    Cache writing successful.
    10:23:15 PM #17 Phase 25 File APIProgress.cpp, Line 250
    Caching of files completed
    10:23:15 PM #18 Phase 36 File APIProgress.cpp, Line 250
    Burn process started at 8x (11,080 KB/s)
    10:23:15 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2264
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    10:23:16 PM #20 Text 0 File Cdrdrv.cpp, Line 7912
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD+R (10), Part Version: 1
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26053F h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Media Specific:
    00 03 52 49 54 45 4B 00 - 00 00 52 30 33 02 38 23 ..RITEK...R03.8#
    54 37 20 00 5D 6C 00 B2 - 67 15 15 0B 0B 08 08 01 T7..]l..g.......
    19 1B 0C 0C 0C 0D 01 00 - 00 00 00 00 00 00 00 01 ................
    10:23:16 PM #21 Text 0 File DVDPlusRW.cpp, Line 603
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    10:30:53 PM #22 SCSI -1039 File Cdrdrv.cpp, Line 1430
    SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x03F80000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x04 (KEY_HARDWARE_ERROR)
    Sense Code: 0x09
    Sense Qual: 0x01
    CDB Data: 0x2A 0x00 0x00 0x1C 0x0D 0xC0 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0x71 0x00 0x04 0x00 0x00 0x00 0x00 0x10
    0x35 0x01 0x04 0x0E 0x09 0x01
    10:30:53 PM #23 CDR -1039 File Writer.cpp, Line 301
    Focus or tracking error
    10:30:53 PM #24 Text 0 File ThreadedTransfer.cpp, Line 229
    all writers idle, stopping conversion
    10:30:53 PM #25 Text 0 File ThreadedTransfer.cpp, Line 223
    conversion idle, stopping reader
    10:31:19 PM #26 Phase 38 File APIProgress.cpp, Line 250
    Burn process failed at 8x (11,080 KB/s)
    Existing drivers:
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    Oct 2005
    666th portal
    i'd get rid of nero and use imgburn. you might also want to try some taiyo yuden or verbatim dvdr blanks.
    another thing might be to use dvdfab and not ripit4me which hasn't been updated in quite a while.
    Nov 2004
    Las Vegas
    rip101,
    The error had nothing to do with RipIt4Me or DvdShrink. It occurred during burning with nero. The drive reported atapi error 040901 (a tracking servo failure), which may mean the drive is dying/dead. To make sure it's the drive, try these changes:
    1) The version of nero you're using is from before your drive was first released, so nero isn't recognizing the drive correctly. In that circumstance, nero is less stable, and strange problems can pop up. You should try using ImgBurn (as aedipuss suggested) for the burning. ImgBurn is free and an excellent program, so you have nothing to lose.
    2) Your burner may be having problems with the Ritek R03 disks you're using. Try even just a few Verbatim disks, just to rule out media causing the problem. With the drive you have, avoid getting more than 8x rated disks, or the test(s) may not be valid.
    3) Your burner's firmware had at least one update, but it seems it would take more time than I have right now to locate it. The drive is a HL-DT-ST DVDRAM GSA-4082B and it is currently using firmware A207. If neither of the two changes above worked, upgrading the firmware is the last thing to try, so it might be worth the search.
    If you are still getting the same error after trying the above, the drive is dying/dead, and should be replaced.
    I see this was your first post here, so welcome to VideoHelp.
