hi
i have 750gb hdd devided to C (system)50gb and D (data)700gb partitions
i am about to buy new 1TB hdd and would like to make 1:1 copy of everything from 750gb to 1TB hdd and swap up those hdds?
how can i do it easily with some software for beginner...? please recommend freeware if possible.
can i do it from windows or not?
thanks for replies
The drive manufacturer will supply a free transfer software. Just visit their website....
i have seagate hdds so what software did you mean?
is it on seagate website as freeware? -
If you bought a retail version of the drive, it came with a software CD containing DiscWizard. This is a utility based on Acronis True Image. If you need to download the software, try the following link:
DiscWizard Download page[/url] -
or you can try xxclone - it's free and it's worked for me on multiple systems
http://www.xxclone.com/I am just a worthless liar,
I am just an imbecil -
Assuming you use the manufacturer's free tool:
Make certain you set up the new hard drive as new *boot* drive. Simple copy won't do. Also specify custom partition, the first partition you add will (should) be the one on which the OS partition is copied. Add however many more you wish. Let the program do its thing. When it's done, do a copy of the data partition to the new one. Simple. :wink: Good luck.Pull! Bang! Darn! -
Just my own opinion, but I wouldn't use a 1TB drive for a boot drive. The OS is constantly accessing the boot drive and this can slow access for other programs that transfer large files, such as video. Using partitions has no effect on this. I prefer a small boot drive and one or two extra hard drives for exclusive video use and just single partitions for all drives. But in the case of very large drives, partitions may be a good idea, mostly for speeding up defragging.
Phlilps DVR520H HDD replace help
By NetKing in forum DVD & Blu-ray RecordersReplies: 18Last Post: 10th Dec 2010, 17:15 -
Copying from standalone hdd recorder's hdd to pc hdd
By flez in forum ComputerReplies: 7Last Post: 6th Dec 2010, 07:17 -
How to put files bigger then 4gb on FAT32 hdd
By WinSpecToR in forum ComputerReplies: 14Last Post: 14th Jun 2010, 07:22 -
How to replace HDD in Sony RDR-HX820?
By Funkmeizter in forum DVD & Blu-ray RecordersReplies: 0Last Post: 10th Feb 2010, 09:47 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 13:38
