Anyone have an opinion or own a TrekStor external hard drive?
http://www.futureshop.ca/catalog/proddetail.asp?sku_id=0665000FS10096146&catid=23795&l...gon=&langid=EN
I'm considering purchasing a 500 gb unit. I would like to know if/when the warranty is up on this unit and the original hard drive dies, can another IDE or SATA hard drive be put into the case? I understand with some external hard drives you can not replace a failed drive with a regular IDE or SATA drive.
TIA
It is a very good drive for the money. I have 3 externals, and this one is my fav. I like how it powers down on its own if it not in use.
It depends on the software (And firmware) the external enclosure uses, but with most you should be able to replace the hard drive with one of the same type, PATA or SATA, 3.5" or 2.5".
What's a good tv for $500
By fairytale00 in forum DVB / IPTVReplies: 8Last Post: 21st Aug 2010, 18:21 -
Mencoder line help for trekstor i.beat move player [linux] - (solved)
By tolostoi in forum Video ConversionReplies: 0Last Post: 2nd Jul 2009, 03:10 -
Best camcorder for around $500
By Hank Kinsley in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 11th Feb 2009, 04:15 -
dvd player +dvix+usb with external 160GB external HD problem...
By spidermen in forum Newbie / General discussionsReplies: 14Last Post: 14th Oct 2008, 20:45 -
VC 500
By jlh050965 in forum Capturing and VCRReplies: 1Last Post: 24th Sep 2008, 11:00
