Hi
i have got sony vegas pro 8.0, i try to import my videos into sony vegas then to find there is no sound.
I have tried a video converter which proved unsuccsesful(prism video converter)
I also have had a problem with after ripping 5 vobs from one of my home movies from my DVD disc.
I imported each vob into Vegas 8 and 4 being 900mb,took about 3 mins to go into the media import box. I then dragged as normal into the frame line each of the vobs only to find some had no sound.
I them saved the whole project.... shutdown Vegas 8 ..and then reopened Vegas 8 and the vobs in the timeline as saved played with sound..... strange to say the least.
As it was a one off project I managed to render all the vobs as one mpeg 2 file and after shutting down Vegas again ..I restarted Vegas again and put the rendered file into the timeline and worked from that ok. -
hi
it says the video codec is mpeg video
It says the audio codec is ac-3
Sony Vegas Pro 10
By av.sorong in forum EditingReplies: 16Last Post: 9th Oct 2011, 12:27 -
Help With Sony Vegas Pro 8?
By Olivia Bishop in forum EditingReplies: 9Last Post: 2nd Mar 2009, 16:20 -
Sony Vegas Pro
By Liquid9Kitty in forum EditingReplies: 2Last Post: 15th Feb 2009, 02:53 -
Sony Vegas 8 pro
By SNK in forum Video Streaming DownloadingReplies: 7Last Post: 20th Nov 2008, 08:09 -
Sony vegas 8 pro help
By jaycool1995 in forum EditingReplies: 2Last Post: 31st May 2008, 13:58
