I have a Philips monitor Model 107T that is super for most things until recently. I've had some problems occur recently all relating to color and the appearance of webpages and photos. I think somehow my monitor's settings have been changed -- or lost themselves, or whatever! How can I reset my monitor to the settings it had when it was new from the factory. Also, am I guessing wrong and should I be looking at something other than factory default settings??? Thank you.
Not familiar with that particular Phillips monitor, but most have a reset button. I have a 150S and it's right on the front. Also try using the degauss button or control on the monitor. That sometimes helps. Most times a monitor doesn't change color settings by itself unless something is failing in it. More likely your problem is in your video card settings.
That monitor appears to be a flat screen CRT, so in your video card settings, you might check your refresh rate to see it's more than 60Hz, up to 85Hz is usually good, depending on your video card. And make sure the resolution is set high enough, probably 1024 X 768 or higher. You also may also be able to reset your video card color, etc., settings. Most of them have to do with color adjustments.
DirecTV into computer onto my monitor?
By xobituaryx in forum DVB / IPTVReplies: 2Last Post: 10th Nov 2010, 00:41 -
Help!! PC Monitor Won't Reset To Factory Settings.
By Aaron1927 in forum ComputerReplies: 1Last Post: 29th Dec 2008, 10:30 -
bios reset, computer freaks out
By gooberguy in forum ComputerReplies: 10Last Post: 16th Jan 2008, 11:13 -
Capturing Halo 3 gameplay from computer monitor to computer
By Jamo in forum Capturing and VCRReplies: 1Last Post: 13th Oct 2007, 00:06 -
JVC XV-S40BK Factory Reset
By mb300e in forum DVD & Blu-ray PlayersReplies: 0Last Post: 17th Aug 2007, 18:58
