If this has already been asked then I apologise.
The issue is not with Shrink as I can read/shrink on one PC no problem.
Put the same disk in another PC. The drive matches the disk and plays through PowerDVD (DVD genie has set the region)
Fire up Shrink and the drive is reported to be different region and more than that the number of changes left is different to what PowerDVD reported.
Something has got a little messed up. Amy thought on a solution. For the user in mind a rip to HDD before Shrinking is not really practical.
Don't use DVDShrink to rip. Why do people insist on doing that? Use another program to rip and then use DVDShrink. Problem solved.
If you think that ripping to a hard drive prior to using DVDShrink is "not really practical", you're nuts. That's the recommended method. Reading directly from a DVD drive like you propose will shorten the life of the drive.
I told what will absolutely fix this issue. It's up to to do it or ignore my advice and continue to have problems. If the user isn't smart enough to rip to a hard drive, they don't really need to be using DVDShrink. -
It's not a problem for me. I can do it blindfold. The problem is teaching someone who could easily get confused by having extra files on his PC
So I asked for advice. Not a lecture.
All I know is that one program is giving the wrong information. The drive
IS set for region 2 but Shrink reports it as region 1
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 22:10 -
Ulead DVD Factory 6 File Format Mismatch
By nala310 in forum Authoring (DVD)Replies: 1Last Post: 17th Jan 2010, 04:20 -
Strange region problem with DVD Shrink re-author
By Jetter68 in forum DVD RippingReplies: 7Last Post: 30th Aug 2008, 15:14 -
Can't remove region restriction using DVD Shrink. Work-arounds?
By csloane@nwnexus.com in forum Newbie / General discussionsReplies: 2Last Post: 7th Apr 2008, 17:04 -
DVD Audio format mismatch?
By Scally in forum Authoring (DVD)Replies: 4Last Post: 17th Jan 2008, 09:07
