I made the mistake and cut my video into like 30-40 single scenes.
I want to change the contrast ... but it takes so much effort doing this on every single scene.
The group-creation also does not work. If select all scenes with Shift, it still does not work.
Is there a way to change the contrast / any VideoFX for all the scenes ?
Using Vegas 8 Trial.
PS: It works if i mark all scenes and drag an preset-contrast effect (e.g. darker, more contrast) into one scene.
But when i change the settings in the window that opens after, it does not change for all !
1. Apply the Fx you want to one clip. Then double click to select the clip. Right click and select copy.
2. Then click once on the next clip. Right click and select "paste event attributes". This applies all effects you have on the first clip to the second clip: video effect, audio effects, etc.
3. Repeat step #2 with each of the remaining clips.
You have to click on each clip one by one to paste, but you don't have to reset the parameters for each effect. -
Are all your clips on the same timeline ? If so, you can apply Event FX to the timeline instead of the clips.
If not, you can save your current project, open a new project and then put this project onto the timeline instead of a clip, and apply your changes across he entire project. This is called Nesting Projects and is covered in the Help files.Read my blog here.
Join m4v splitted with mp4tools?
By Cartman in forum Video ConversionReplies: 2Last Post: 10th Jan 2012, 17:12 -
Joing mkv files when they are not splitted at keyframes
By wateshadon in forum EditingReplies: 1Last Post: 11th Jul 2011, 14:01 -
splitted AVI files
By merovingio in forum Newbie / General discussionsReplies: 1Last Post: 28th Mar 2011, 08:45 -
Problem in merging splitted AVI files of a movie into one.
By nick2712 in forum Newbie / General discussionsReplies: 8Last Post: 2nd Oct 2010, 15:20 -
Sony Vegas Pro 8 - Adding VideoFX to many video clips at once.
By jnaizer in forum EditingReplies: 2Last Post: 30th Dec 2008, 21:28
