hi,
my notebook was recently infected by a "coolwebsearch" malware and after successfully killed by spyware terminator, now everytime i shutdown & restart there's a popup complaining that :
LogonUI.EXE - Unable to locate component
This application has failed to start because Image.dll was not found.
Re-installing the application may fix this problem.
the image.dll was the problem malware file and was deleted but i think it has already corrupted the logonui.exe
does anyone know how to resolve this? btw it's running windows vista home
thanks in advance
You might take a look here: http://www.file.net/process/logonui.exe.html Also with a Google search for ' logonui.exe ', you should find other information.
I would also suggest a better anti-spyware product. CoolWebSearch is one of several pieces of spyware we regularly remove (MyWebSearch and FunWebProducts are also high on the list) and we manage to do it without undue damage to the machines we are cleaning. We use Spybot Search and Destroy 1.5
Read my blog here.
Virtuadub 1.99 with plugin pack, unable to locate avc1
By Mark669 in forum EditingReplies: 21Last Post: 16th Dec 2010, 11:29 -
winhlp32.exe for Vista
By Willy5157 in forum ComputerReplies: 4Last Post: 15th Sep 2010, 18:21 -
MeGui -> Unable to locate libsndfile-1.dll and FFTW3.DLL
By whatever911 in forum Video ConversionReplies: 0Last Post: 21st Feb 2009, 15:34 -
unable to register on vista
By ukpot in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Feb 2009, 16:44 -
Winodws vista explore.exe problem
By Wizard23 in forum ComputerReplies: 9Last Post: 4th Oct 2007, 01:31
