I have been doing extensive research to find a good way to capture all my PAL VHS tapes that is over 10+ Years old on to the PC with the best possible quality. I tried a few cheap USB capture device and they did not produce satisfactory results. So I decided to bite the bullet and jump into the much more advanced ADVC 300. Some of the tapes contains very precious memories that I want to preserve before they all degrade away.
Many of my OLD VHS tapes are actually recorded footage from my VHSC (mini VHS) camcorder and all are in PAL format. Thus they are quite noisy and the camcorder only has Composite out. Will the ADVC 300 do a good job a cleaning up the signal, especially in terms of the noise, artifacts and general annoyance from an analog source? I read on the spec that it has hardware digital noise reduction and edge sharpening.
The reason why I jumped from a $70 device to a $500 device is because the cheap capture device do not have any hardware based image enhancement. I must use virtualdub and filters to clean up the video, but after comparison, the filtered video looks worse than the original video.
Maybe some of you guys here can answer my question
Here are some screenshots of the videos in question. THey are raw untouched AVI captures:
http://img224.imageshack.us/img224/3296/86556093qi7.jpg
http://img224.imageshack.us/img224/3154/76595024ru5.jpg
http://img68.imageshack.us/img68/3457/32241640jg0.jpg
http://img520.imageshack.us/img520/835/37802811zu9.jpg
Do you think the ADVC300 will do a good job a cleaning and enhancing those videos?
Thanks!
No.
ADVC300 is a great way to capture VHS tapes, but beyond that, the build in TBC and the build in filters are not something to rave about. The cheapest DVD standalone recorder on those 2 matters do a better job IMO.
Better invest to ADVC110 and buy NeatVideo (for virtualdub or whatever). Also get a good VCR with TBC (but from the pictures you provided, I don't think that you need a TBC).
Also prepare yourself to get a very good PC, with C2Q9450 for example.
OR: Get a good DVD standalone recorder. You gonna have the 85% of the best possible results, in less cost and less time. -
Some VCRs have reasonable DNR built in.
The software DNR can be very good - it shouldn't make your images look worse if you choose and use it carefully. It's painfully slow though.
Images will look plastic-y if you overdo the noise reduction. Your don't look that noisy - concentrate on the chroma (which is a mess) while being very gentle with the luma.
The whites and blacks in your images are clipped. You'll have to get the levels right somehow - probably before you capture. The ADVC300 has some kind of limited level control.
The ADVC300 DNR introduces artefacts if you use the stronger settings. I don't have one, but I've read this from several different users in various forums.
I have the ADVC110. It's very good, but I did need a TBC - with it switched off, vertical lines are slightly wobbly, and this is on S-VHS-C originals.
There are two ADVC forums on the manufacturer's website with excellent technical support...
http://ediusforum.grassvalley.com/forum/
EDIT: I see you're already there!
Also, look at the threads in the restoration forum (here at videohelp) on VCRs - an S-VHS one with TBC and DNR is a good idea, even (especially) for VHS.
Hope this helps.
Cheers,
David.
Best VCR to clean up old VHS camcorder tapes?
By dubarry in forum Capturing and VCRReplies: 1Last Post: 26th Jan 2011, 03:09 -
How do I use the Sony EV-S3000 TBC to enhance VHS tapes?
By yoda313 in forum RestorationReplies: 5Last Post: 22nd Jan 2011, 08:52 -
VHS transfer - ADVC-300 with TBC-1000 and BVP-4 - Potential Problems?
By OldMedia in forum RestorationReplies: 9Last Post: 10th Aug 2010, 02:33 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
ADVC-300 Adjusting Image Settings - Need another ADVC?
By MitchJi in forum RestorationReplies: 0Last Post: 1st Apr 2009, 13:36
