    Feb 2002
    Under The Sun
    Hi all, this is my 1st post Okay here goes: I have a Concert On DVD and would like to back it up to VCD but when i rip the vob files and use "dvd2avi version 1.76" I always get a large file (too large for a single 80 min cdr).
    Information You Might Need To Know:
    1. Picture Format = PAL 4:3
    2. Concert Duration = 88 mins
    What I would like to know is:
    1. Can I use Any Settings To Make The File Small Enough To Fit On A Single 80 min CDR Even If It Means Losing A Little Quality ?
    2. Are There Any Charts Online That Will Tell Me The Best Method To Use With Certain DVD Duration?
    Any Help Greatly Appreciated, Thx In Advance
    P.S. I have tried countless online guides with no avail
    TheEverLiving
    "Smell The Flowers Whilst You Can."
  2. if you dont want to violate the standard try 90/99min media. otherwise, a bitrate calculator is all you need
  3. Member spidey's Avatar
    Apr 2001
    U.S.A.
    If it doesn't need to be a disc to strict standards, use one of Sefy' SxVCD or SeVCD templates. They'll get approximately 95 minutes on a disc. You may have to trim out the credits or something...
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
    Feb 2002
    Under The Sun
    Thanks Both Of You where can i find sefy's templates and will they work on my vcd only dvd drive as there is no mention of a SxVCD or SeVCD compatability
    My DVD Player Is A Matsui DVD 110
  5. TheEverLiving, you can find my Templates on the Tools section in VCDhelp, or more updated ones on Pinoy's homepage, as for compatibility, I doubt a VCD Standalone will accept them, it "might" work with SeVCD, but defenetly not with SxVCD.
    If you are using a DVD Standalone, i suggest you try with a CDRW media.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
    Feb 2002
    Under The Sun
    Hi again thanks alot....i'll give it a whirl
