Hi.
Yesterday i tried to hardsub one of my avi file with subtitle workshop. virturaldubmod, virtualdub subtitle filter and divx5 codec. The result is quite sastificing. But today for some reason i can not see the softsub when i play with my storm codecc. I´ve doublecheck the file´s namne, they are all correctly typed. There are not any problems at all while play an avi file with softsub before. Some of the movie have the same text but double instead.
I´ve removed subtitle workshop and others but still without good results. Anyones have any ideas how i can solve this problem.Please guide me so my computer can run normally. Thanks
Hi, and welcome to VideoHelp!
Please use a subject that describes your question. I changed it for you this time.
As your question is hard to understand, and I may have misinterpreted it, you may change it again by editing your post above.
/Mats -
Thanks for help. I´ll remember next time about the topic.
Just found out that the movie´s file that i want to watch it has the ending like this filename.avi. But when i open with media player classic it change to (filename.avi.avi) and my srt file only ends with (filename.srt). That´s why i can´t see the softsub.
Any ideas why media classic acts like this. Thanks -
That's because you have the option "hide extension for known file tyes" (Dölj filnamnstillägg för kända filtyper) i Folder Options/Mappalternativ.Windows Explorer is hiding the last ".avi", but mpc shows it. Disable that very stupid Windows default, so you see what file types you're dealing with.
/Mats -
Man får tacka för hjälp...Ha klurat på problem rätt länge men kunde lösa det. Jag får nog övergå till engelska.
Where can i find folder option. Please guide me.
Never mind. I found it and problem is solved. As you said that is really a very stupid default setting. Anyway thanks again.
Wy doesn 't show Windows Mediaplayer subtitles while paying mp4
By strannoboy in forum SubtitleReplies: 23Last Post: 25th Jun 2017, 00:14 -
Burn AVI + SRT, but doesn't show up on TV
By waro in forum SubtitleReplies: 3Last Post: 19th May 2009, 11:21 -
Multi-stream OGM to hard subbed AVI
By bizzybody in forum Newbie / General discussionsReplies: 4Last Post: 26th Apr 2009, 00:33 -
Subrip and Hard Subbed Video files - does it work?
By Jeremiah58 in forum SubtitleReplies: 3Last Post: 23rd Aug 2008, 11:01 -
creating hard-subbed mkv videos--subtitle problems
By RainGoddess in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2007, 05:25
