Hi all,
first post here. just wondering if anyone has any tips on what to do when i encounter bad audio while converting from mkv to mp4?
MeGUI is the only program that doesnt crash and it just encodes a dummy file of about 4mb (original is a 300mb ac3 file).
ive tried several ac3 fix programs (which convert it to a raw wav format) but then the audio is horribly unsynced with the video. vlc transcode outputs a dummy file.
my question is: is there anything else i can try or am i stuck with a file i can't convert?
Hi.
Sorry friend i can't help you, because i don't have any idea of that. -
You can't put AC3 into an MP4 container. You have to convert it to AAC.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
[solved]What is the proper way to fix an ac3 synch issue in a h264 mkv file
By yoda313 in forum AudioReplies: 0Last Post: 16th Apr 2011, 10:46 -
How to fix uneven audio volume in MKV/MP4/AVI files?
By ConverterCrazy in forum RestorationReplies: 5Last Post: 19th Jul 2010, 00:26 -
Join .MP4 with .AC3 to .MKV without loss of sync
By vanleeuwen in forum Video ConversionReplies: 2Last Post: 18th Dec 2008, 03:53 -
MKV to MP4 for PS3 with dual-audio (2ch AAC + 6ch AC3)
By sexyclient in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th Dec 2008, 23:01
