I'm playing around with Boris in Sony Vegas today...and I am trying to do an effect where a video is revealed by brushstrokes using the brush tool and mask. It looks totally fine in the Boris Composite window, but when I apply and return to the Vegas timeline to play it, the effect appears offset to the upper left hand corner of the clip. Does anyone know how to fix this so that the Vegas preview will be the same as whatever I saw in the Boris screen? Thanx...
seems the same happened to me...in vegas under project settings
I don't want to mislead you because I'm not familiar with Boris...
however, I had the something like your probelm happen once and I solved it by changing the aspect ratio
you'll just have to play around with the settings to see if you can get it...or pray this bump works
How may I access to Boris RED 5 in SONY VEGAS 11?
By daniel827 in forum Newbie / General discussionsReplies: 4Last Post: 8th Jan 2012, 23:39 -
Sony Vegas Pro 8
By Jules2 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Mar 2009, 20:59 -
Help With Sony Vegas Pro 8?
By Olivia Bishop in forum EditingReplies: 9Last Post: 2nd Mar 2009, 17:20 -
Sony Vegas Pro
By Liquid9Kitty in forum EditingReplies: 2Last Post: 15th Feb 2009, 03:53 -
Sony vegas 8 pro help
By jaycool1995 in forum EditingReplies: 2Last Post: 31st May 2008, 14:58
