The following is my script for ripping a DVD and converting it to XVID. The resulting video looks very blocky in appearance and parts of the video are very purplish in color. I'm looking for some advice to tweak this script to produce better output.
Thanks in advance.Code:#! /bin/bash TITLE="title" BITRATE="777" CROP="720:352:0:62" SCALE="628:265" dvdcpy -o /tmp/dvdrip -m -t 1 /dev/hda mkfifo /tmp/audio.fifo mplayer -quiet -nolirc -nocache -noframedrop -mc 0 -vc null -vo null -ao pcm:nowaveheader:file=/tmp/audio.fifo -af volnorm=1 -channels 2 -aid 128 -dvd-device /tmp/dvdrip dvd://1 & oggenc -r -R 48000 -q 3 -C 2 -o /tmp/audio.ogg /tmp/audio.fifo rm /tmp/audio.fifo mencoder -nocache -noslices -oac copy -aid 128 -sws 7 -zoom -vf crop=$CROP,scale=$SCALE,hqdn3d=2:1:2,harddup -mc 0 -dvdangle 1 -o /dev/null -dvd-device /tmp/dvdrip -ovc xvid -passlogfile /tmp/xvidpass.log -xvidencopts autoaspect:par=vga11:chroma_opt:vhq=4:bvhq=1:quant_type=mpeg:nocartoon:noqpel:turbo:trellis:nogreyscale:nogmc:max_bframes=2:bitrate=$BITRATE:pass=1:threads=2 dvd://1 mencoder -nocache -noslices -oac copy -aid 128 -sws 7 -zoom -vf crop=$CROP,scale=$SCALE,hqdn3d=2:1:2,harddup -mc 0 -dvdangle 1 -o /tmp/video.xvid -dvd-device /tmp/dvdrip -ovc xvid -passlogfile /tmp/xvidpass.log -xvidencopts autoaspect:par=vga11:chroma_opt:vhq=4:bvhq=1:quant_type=mpeg:nocartoon:noqpel:trellis:nogreyscale:nogmc:max_bframes=2:bitrate=$BITRATE:pass=2:threads=2 dvd://1 ogmmerge -o "/tmp/$TITLE.ogm" -c "TITLE=$TITLE" --noaudio /tmp/video.xvid -c LANGUAGE=English --novideo --notext /tmp/audio.ogg
How do the original frames of these two frames on the DVD look like?
777? Isn't that a bit low? Did you try raising the bitrate?
What was the average quantizer for this encode? Seems pretty high. You can check this by running the file through DivX DRF Analyzer. DRF = Quantizer. -
I seemed to have fixed my problem by changing quant_type=mpeg to quant_type=h263 and lowering the frame rate slightly, which improved the quality. I need the bitrate to stay low to make the resultant file fit on a 700 MB CD-R.
All seems fine now, but feel free to add your two cents to my options
OK. If H.263 looks OK to your eyes, then by all means use it. If you are aiming for 700 MB, then you need to use a softer matrix like H.263, and also a softer resizer like Bicubic.
What do you mean by lowering the framerate though? Frame rate as in fps of the movie?!
Correct mencoder options?
By wl2776 in forum Newbie / General discussionsReplies: 0Last Post: 11th Mar 2011, 10:22 -
Mencoder config and and command line -vf options not working together?
By AlexGrim in forum DVD RippingReplies: 0Last Post: 1st Dec 2008, 12:00 -
Please, best options for mencoder? (high quality reencodings and no blocks)
By BlooderButcher in forum Video ConversionReplies: 1Last Post: 21st Nov 2008, 13:53 -
mencoder options NTSC 29.97 -> PAL 25 fps with a/v sync
By menket in forum Video ConversionReplies: 3Last Post: 8th Oct 2008, 07:04 -
Video Configuration tweaking...
By NHRaider in forum Media Center PC / MediaCentersReplies: 19Last Post: 15th Jul 2007, 14:16
