i have download some movies from online which were .AVI format, and i have converted those format to DVD format which were Audio_TS and Video_TS files, then i using the Nero to burning those files to a dvd disc. after i played in the sony player it can't be play out . it show something prohibite.... does anybody it how to fix it . i would be very appreciate for it. thank you..
if you are in the states then the avi probably need to be ntsc while being encoded to dvd spec mpeg-2. avi's are usually 25fps (pal) and u.s. sony's are known for not playing pal.
What program did you use to convert the AVI to a DVD format? And I would recommend ImgBurn instead of Nero most times for burning. Also, what brand of DVD media are you using?
A prohibition error most times is from something done during the conversion process, such as a improper video/audio format or something out of specification with the DVD format. Do you have the exact wording of that error?
EDIT: aedipuss has a good point about PAL video. You can drop one of the VOBs from the DVD into Gspot and see if it shows up as 25fps video. Then that could be your problem. A converter program like ConvertXToDVD or FAVC should be able to convert the original file to NTSC, which is the format used in the US. -
Originally Posted by redwudz
well i can playing in some other kind of dvd players like toshiba. do you think it could be a regions free problem. -
no, sonys don't do pal in the u.s.
thank you for all the suggestion above.
i already solve the problem
Old Sansui dvd player DV-X2850K New Sony DVD recorder
By georgewbell in forum Newbie / General discussionsReplies: 1Last Post: 13th Nov 2011, 16:18 -
My Sony CD/DVD player (NS55P) would almost only play sony discs.
By valdes001 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 30th Jan 2011, 11:03 -
Trouble with SONY DVD+R disc and SONY player/recorder
By Winston99 in forum Newbie / General discussionsReplies: 3Last Post: 29th Mar 2010, 23:54 -
My Sony DVD player SONY DVP- NS718 H
By samyer in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2010, 00:56 -
Playing region free DVD on Sony SR200P DVD Player
By merik in forum DVD & Blu-ray PlayersReplies: 5Last Post: 25th Nov 2009, 16:35
