Results 1 to 13 of 13
    May 2008
    ''Unsupported codec (id=74) for stream input #0.1'' is the error I get when trying to convert my video from .wav to .avi .
    Any solutions / downloads?
    Oct 2005
    666th portal
    try to id the needed codec, something like gspot might help.
    May 2008
    Where and how would I find out the needed codec, I've download it and opened the specific file, but I don't know what to do next..
    I press 'Vid: 1' and it says 'GSpot isn't capable of attempting to render this video type', it says the same with 'Aud:1 ' and suggests using the MS A/V button but that says ''Rendering Failed: Following is the error shown by DirextShow - 0xc00d0bbe: [unknown]
    May 2008
    Any solutions?
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Post a screenshot of g-spot after you open the file
    Read my blog here.
    Jan 2007
    Republic of Texas
    I am reading your first post, and it looks like you are saying that your original file is a .wav file. Is that correct? Wav is an audio format only.
    May 2008
    http://i32.tinypic.com/27xf2tg.png
    My bad, I meant .wmv :P .
  8. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    if you have any windows media player higher than 7 installed it should play. if it doesn't it may just be a bad video file. one thing you could try - installing this ms "helper" codec, it might work.
    http://www.microsoft.com/downloads/details.aspx?FamilyID=0C99C648-5800-4AA3-A2FE-3DE94...displaylang=en
    May 2008
    Still no luck mate, hasn't changed a thing..
  10. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    does the video play in windows media player?
    May 2008
    Yep.Is it a possibility that it won't convert because it is protected by Digital Rights Management?
  12. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    possible, google remove drm from wmv and you might get a few hits, but unless it's something you purchased and have the "key" to it's not likely you can convert it.
    May 2008
    I downloaded TuneBite and did it all successfully, not it works.
    Cheers for the help guys.
