there are a few applications that will and cannot be removed via Add/Remover Programs for some reason, I have successfully deleted "Windows Messenger", the really old one by selecting RUN and running a command, but I cannot find a way to delete MSN Explorer
msn explorer is in add/remove programs - but it's found by clicking add/remove windows components in the left column. might be in the accessories and utilities section.....
alright, thanks, it all works, what are windows components anyway, are they just built in stuff?
clicking on links in msn
By angryassdrummer in forum ComputerReplies: 4Last Post: 16th Feb 2011, 02:40 -
How do you search old news stories on msn.com?
By yoda313 in forum Off topicReplies: 0Last Post: 12th Dec 2009, 10:17 -
Msn Messenger
By gooberguy in forum ComputerReplies: 1Last Post: 18th Dec 2008, 12:42 -
What have MSN done to Hotmail ?
By cyflyer in forum ComputerReplies: 6Last Post: 3rd Feb 2008, 10:51 -
MSN Messenger ring
By winifreid in forum ComputerReplies: 9Last Post: 10th Sep 2007, 18:15
