Hello
I have tried everything- AnyDVD (could not rip, gave error), DVDFab HD Decrypter (ver 4 could not complete recognition and ver 5 only copied .99GB), DVDDecrypter. In DVDDecrypter I got the error as mentioned in the title though the disc is ripped. Unfortunately the ripped folder also has the hitch. I tried to do a 100% backup using shrink, but the result was having the same fault.
The disc is not at all copy protected. The disc can not played without a hitch in VLC, but PowerDVD plays it fine. There is a problematic portion I understand where VLC simply closes. In stand alone PHILIPS player also, I found that there is a hitch at that point of the movie.
Is there any way that I can fix the Disc if I can rip it successfully?
Please help.
Thank you.
আমি বাংলায় গান গাই
Have you tried RipIt4Me? I don't know if it'll work for your instance, but I've had success with it before where DVDDecrypter and DVDFabDecrypter had failed.
Yup, tried that too. But as it uses DVD Decrypter, that also gave the same error.Originally Posted by bevills1
আমি বাংলায় গান গাই -
Try a simple Windows copy and paste?
Or set DVDDecrypter to ignore read errors? -
I did try that....did not helpOriginally Posted by hech54
How do I do that? I will give it a try.Originally Posted by hech54
Thank for replyingআমি বাংলায় গান গাই
DGindex "NO video sequence header found"
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 28th Apr 2012, 08:41 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
Help the specified procedure could not be found error
By mn072065 in forum ComputerReplies: 6Last Post: 7th Oct 2008, 21:14 -
.mkv: no EBML header found?
By rotuts in forum MacReplies: 1Last Post: 31st Jan 2008, 08:56 -
DGIndex: No video sequenze header found!
By messo in forum Video ConversionReplies: 4Last Post: 12th Aug 2007, 11:42
