I have a ATi 3850 video that says it will offload VC-1 and h264 video decoding onto the GPU. I'm using Media Player Classic with COREAVC code to decode h264 videos right now but my CPU is still doing all the work. How do I get my GPU to decode h264 instead of my CPU? Ati states that's what their Universal Video Decoder (UVD) does but I can't seem to get it to work.
The further away I get from the things that I care about...
the less I care about how much further away I get... -
If your listed computer specs are current, it is because you are using XP. UVD is only supported in Vista 32bit.
Google is your Friend -
I discovered the answer in another forum. I think you need to check your facts because it can mislead other people. GPU offloading is done if the video codec supports it. Currently CoreAVC cannot offload decoding to the GPU. Codecs used by PowerDVD supports hardware acceleration, http://www.cyberlink.com/multi/cyberstore/order_77_ENU.html
I wasn't trying to mislead anyone. I referenced an article from HardOCP http://enthusiast.hardocp.com/article.html?art=MTM2MCwxMSwsaGVudGh1c2lhc3Q=
However, there appears to be a difference between UVD implementation between chipsets and there have been driver and software support updates.
Sorry for misleading you.Google is your Friend -
Anything that requires you to use Vista to work is complete b.s. in my opinion. Yet another reason to add to the list of why I hate ATI.
Didn't you get the memo? You should know everything.
Yeah, his reply was... dramatic?
What form of h264 will VideoRedo h264 tvsuite accept?
By Asterra in forum Video ConversionReplies: 4Last Post: 12th Apr 2012, 13:22 -
Problems converting some xvid to h264 to append to another h264
By PlanetIndigo in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 14:13 -
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 19:06 -
Can I offload SYSTEM_SAVE from an old Compaq Presario?
By ahhaa in forum ComputerReplies: 2Last Post: 11th Jul 2008, 14:38 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 01:20
