I have an avi with two audio streams. All software I have does not allow me to choose the non-default stream in vob conversion.
Does anyone know a software that allows this?
Thanks.
Try DVD2SVCD. It's free and despite the name, it can do AVI to DVD encoding. If it can open your AVI file, it should be able to let you select which audio stream you want. It's also possible to use Virtual Dub Mod to open your AVI file and open the audio streams and save a new copy with only the audio stream you want. Deselect the audio stream you don't want and save your copy in "Direct stream copy" mode and you'll save a copy of the AVI with only the audio stream you want. Then you should have no problems to encode it with whatever you like.
Many thanks, I had looked in Virtual Dub with no luck.
Virtual Dub Mod did the job admirably. -
Hi, jman98.
Thank you very much for your nice information. It’s really very useful for us.
Convert DVD to avi with 5.1 audio to stream to 360
By johnmactavish in forum User guidesReplies: 7Last Post: 14th Jun 2011, 19:49 -
How to choose audio track in avi file with two audio tracks
By newnews in forum AudioReplies: 3Last Post: 26th Oct 2010, 06:26 -
MKV to IPOD conversion with the audio track that I choose. Wich software?
By fgtan in forum Video ConversionReplies: 5Last Post: 15th May 2010, 00:09 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27 -
how do i choose the right audio track going from avi to dvd output?
By kenzo69 in forum ffmpegX general discussionReplies: 3Last Post: 23rd Jul 2007, 20:36
