    Jun 2007
    I have a problem DVD Drive in my PC
    Sometimes it recognizes the DVD-Ram video files and lets me see them on the DVD, to copy them
    Other times, it loads as an empty DVD Ram disk
    I am dubbing from a Pana HD-Recorder to DVD Ram
    Any Ideas why I cant always see the video files, or how to mount the DVD Ram properly in the PC
    Many thanks
    Maybe the dvd recorders makes multisessions dvdrams and windows just read one multisession. You could try isobuster and see if it finds any files when windows doesn't.
    Jun 2007
    Thanks, but it didnt help
    A few discs have shown data, but most dont - I am having to do this because my Pana EDH50 wont burn to a DVD any longer, but will still copy to a DVD-Ram - I am then trying to get the files off the DVD Ram onto a PC, to finalise as a DVD
    Odd DVD-Rams have shown up, but most haven't, and I cant work out why - might it be that I need to format the DVD-Ram on the Pana recorder before transferring title?
    isobuster recognizes the drive as a dvd ram
    any thoughts
  4. What drive is it? Some require DVD-Ram drivers.
    Nov 2000
    Canada
    I have this happen with my LG-55L not recognizing discs. I usually have to reload them several times before the drive will accept them. This is probably the worst drive I have ever owned and I'm pretty well fed up with it. It takes a long time to erase the discs as well. My older model LG-4163 does them in 10 seconds while the LG-55L can take a couple minutes. If your drive is older, it might be a failing laser or mechanical problem. Might be time to upgrade to a new drive.
    Jun 2007
    its not old - its a new laptop with a optiarc ad-7530a, although i cant see this mentioned on the optiarc web site
    its a bummer really - it clicks away for a few secs, and then doesnt recognize theres adisc loaded - although once or twice it did!
    i'm going to ttry formatting the disc in the dvd recorder, before transferrring tracks next time
