i just got a Panasonic PV-GS500, i have a telephoto and wide angle lense for it with a bunch of filters to use, 2 tripods, 2 batteries, bunch of miniDV tapes, etc...
i actually got this camera from Tom Green, he was selling his old cam's on ebay from his online show since he is going to HD now, the camera isn't of studio quality or anything, but it seems pretty good, altho the GS400 would be nicer from what i hear.
basically i'll just be using this to record some car races, some in car shots, drag races, auto-cross and doing some creative little videos myself.
is it worth it to buy a better mic and more lenses for this? or just use it as point and shoot as most think its made for?
Pro: A 3CCD SD cam with good daylight capability.
Con: Limited manual exposure and audio control vs. GS400 or higher end Sony VX2000. Not great in low light.
A wide adapter is always useful. Beyond that it depends on your production plan.
This is a good read.
http://www.camcorderinfo.com/content/Panasonic-PV-GS500-Camcorder-Review.htm#Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
gotcha. i think i will get some lenses now and a light. just not sure about what lenses i can buy?
Originally Posted by ShadowParadox
Get some experience before spending money. Understand the problem before looking for a solution. The stock lens will cover most needs. You just need camera positions that get closer in the turns where cars are moving slower, then let them speed into distance. The wide adapter is useful for close in hand held shots.
This is what the pros use. Note tripod and isolated fly by wire pan/tilt/zoom controls. Actual fine pan/tilt/zoom is done by fluid damped motors with manual override for repointing the cam.
These are examples of remote/isolated zoom controls for other Panasonic camcorder models. Look for one that works with the GS500 and your tripod.
http://www.b-hague.co.uk/Panasonic_remote_camcorder_control.htm
Another approach is a jib or pole mount with full remote.
http://www.b-hague.co.uk/pan__tilt_power_head.htm
which Panasonic camera model?
By incagraphy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 10th Jun 2013, 11:27 -
watch movies on a panasonic camera ?
By kissber in forum Newbie / General discussionsReplies: 4Last Post: 13th Feb 2012, 22:46 -
Problems using a Panasonic DV camera (NV-DS50) in my firewire
By Duck_Plumber in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 10th Apr 2010, 09:10 -
panasonic lx3 stills camera movie mode
By charlietoosey in forum MacReplies: 0Last Post: 18th Dec 2008, 05:46 -
Capturing from Panasonic BL-C30A network camera
By bemasher in forum CapturingReplies: 0Last Post: 1st Sep 2007, 17:17
