I used DVD2AVI to get the .wav file from a DVD film. The audio file is about 6 seconds longer than the actual film. The video and audio started in sync, as the film goes, they became more and more out of sync. If I disable the forced film option. Both video and audio are longer than the actual film and they are in sync. Is this a bug in the program or did I do something wrong? Thanks for your reply.
Vince
The film is probably irregularly telecined, in which case forcefilm won't work quite right. I suggest manually inverse telecining using the filter in TMPGEnc or Avisynth.
Thanks for the information. Do I need to find out which part I should do inverse telecine or just do it for the whole movie? What parameters should I use? Will the movie be 6 seconds longer than the original? Thanks again.
Vince -
I would definitely recommend allowing the inverse telecine filter to operate on the whole movie, otherwise you could have very unpredicatable results. What parameters are you unsure of - are you referring to TMPGEnc? And yes, in my experience the resultant playtime doesn't always exactly match the declared movie length, but having the audio in sync is certainly more important, I think.
Episode 6 Bug? Or Quicktime Player 7 bug?
By NY2LA in forum Video ConversionReplies: 3Last Post: 25th Jun 2012, 16:59 -
FFMPEG adding audio to mpg video => QT bug
By Tom2me in forum MacReplies: 3Last Post: 6th Aug 2011, 05:27 -
Sony Vegas 8.0b - Bug with Audio Tracks
By Cunhambebe in forum Newbie / General discussionsReplies: 0Last Post: 21st Jan 2008, 13:17 -
No HDMI audio output
By tcheema in forum DVB / IPTVReplies: 2Last Post: 11th Jan 2008, 22:00 -
audio -bug while encoding flv
By Ctracks in forum ffmpegX general discussionReplies: 0Last Post: 1st Aug 2007, 07:22
