I have a family video in avi format, which is about 1.2GB in size. I want to share it with my relatives through internet. Anybody please help me suggesting how to share that file, so that the video quality would remain pleasant for viewing.
I am in deep thought. Please help.
Results 1 to 22 of 22
regards
anindyanuri
what format avi is it? DVavi, wmv, divx....... or what is the source of the avi. it most definitely needs to be reduced - by about 90% before you could even think of putting it online.
Probably DVAvi,
I created this file using Ulead Video Studio.
Share Video Files-> DV -> NTSC (16:9) and saved the file as .avi (File Type : Microsoft AVI).regards
anindyanuri
Output as a WMV instead, I believe in the ulead program there will be the standard profiles listed for different qualities and file sizes. Experiment to find a reasonable one. That should get down around 200MB at least.
There are places you can upload large files like that but I don't use those services so I can't recommend one. -
i am also not in favour of uploading that much large file.
ok, i'll try to reduce it by your suggested way. it will be good, if it comes down to 200 mb.
thank you for your suggestion.regards
anindyanuri
may you please suggest for a quality which should be plesant for viewing?
regards
anindyanuri
if you can encode it to mp4 you might get it down to 100mb. try it and see if the quality is ok to you.
is it possible to upload mp4 file to youtube?Originally Posted by aedipussregards
anindyanuri
Depending on your upload speed, and / or your family's download speeds, an alternative is to load the file to www.megaupload.com (or similar) and then send them the URL to download it from - you'll get this once the upload is complete. It's a free file sharing website.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I used AllPeers which ran on firefox. Created a torrent which you shared via email. You ended up with a small peer network with which all those invited cross shared your files. It's now gone.
This works approximately the same. A small learning curve for this.
http://www.gigatribe.com/tour/accueil.php
Maybe useful to you. -
here's the info for uploading to youtube.
http://help.youtube.com/support/youtube/bin/topic.py?topic=10524--
For anyone wanting to keep the filesize - I recently uploaded a 1.1gig video file (mpg) , put it into a multipart RAR file , which I setup to create into 98meg parts (using WinRar - select size for zip 100meg) . 100megs is a standard size for upload sites (there are upload sites that are bigger but if you upload 98% of a 1.1gig then it drops the connections , then you`re gonna cry a bit) . I used www.Mediafire.com to then upload the parts . My connection was taking about 30-40 minutes to upload each part ...mind you , the personal torrent file idea (above) seems a better solution .
Is there any possibility of burning it to DVD and then mailing it? Are the relatives in one place, or are there several different locations?
I would also suggest torrents.
Another possibility is to ftp it, maybe with something like Filezilla - http://filezilla-project.org/ -
You may upload the original file using the free services of www.yousendit.com. I use it all the time. What you do is upload your file to the site and then they send an email to whomever you desire containing a link to the file. You will also receive an email containing the link, which you may give to others. I believe that file is available for downloading for seven days.
The techniques used by Usenet users to break up large video files and error check them might be useful.
This wil require software on both your system and software like quickpar on the recipient's system.
Start by reading about Usenet conventions in the wikipedia.
Another posibility - use hjsplit to break the file into multiple smaller files and then to rejoin on the recipient's system. This is freeware -
I wasn't looking to diss your suggestion here, but I recently tried to guide some not-terribly-computer-savvy relatives though some large-file xfers using this service . . . and the results were very unimpressive, to say the least. There were multiple Send failures, plus looping you back around to where you started again (account registration + email confirmation). Finally, it said that files had been sent, but within a few hours we knew that nothing was received at the other end. I'd have to give this one a big Thumbs Down.Originally Posted by jehill
There are quite a few of these services around. I've used Rapidshare several times, but only to receive, never to send. It can be a pain in the rear, but it works. All of these things try to steer you towards their paid and premium services -- no great surprise, 'cause the freebie versions ain't gonna pay the rent. They all make you jump through a certain number of hoops for the free service. And you have to check up on them periodically, because they may substantially change the rules at any time. There is one I had liked and used previously (can't recall which just now), that looked totally different when I went back there the other day: much more burdensome in their requirements and much more paid-service oriented than before. Right now, I would probably lean more towards Megaupload. But that is very much subject to revision and further research. If anyone here has strong recommendations on which free service is the most user-friendly and has the lowest hassle factor in their requirements, please let us know.
Torrents are a non-starter, IMO. We haven't got a couple weeks of downtime (with the computer left ON constantly, during this process), to wait for the damn thing to seed and trickle across.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
Sorry about that. I see that the file size limit for the "free" service is only 100MB.
You may also want to read the fine print on a lot of these image and video upload sites. By using the service you are usually granting them a license to use the material elsewhere. I think this is one wat they make their money back especially with the images. It allows them to amass a huge stock of images which they can then in turn license to others.
Really ?! Yeah, but if it's -- say --- a collection of family photos, including images of non-famous people long dead, what the hell they gonna do with that ? Doesn't seem to offer a whole lot of licensing potential . . . .Originally Posted by thecoalmanLooking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
You're right, of course; but, for every person who uploads a group of family photos, there's somone else uploading landscapes, hot girlfriend/boyfriend photos, the list goes on. And, we may all be surprised at what some parties will pay for.Originally Posted by Seeker47
They probably don't care about the family stuff, beware other stuff, though. -
I use Sendspace a lot (300MB max upload).
I've also sent DVD vobs (~4GB's worth) through Soulseek.
Webcam video file too large (AVI)
By zerozenones in forum Video ConversionReplies: 3Last Post: 13th Sep 2010, 15:32 -
How to transfer large file directly between 2 computers without P2P
By moviebuff2 in forum Newbie / General discussionsReplies: 15Last Post: 19th Jan 2008, 14:23 -
AviSynth and unusually large video file.
By Holonet in forum EditingReplies: 1Last Post: 7th Aug 2007, 02:51 -
Large Video File to burn to dvd
By jbristow in forum Authoring (DVD)Replies: 8Last Post: 15th Jul 2007, 04:49 -
Video Format For Internet Transfer
By pbmc59 in forum Newbie / General discussionsReplies: 7Last Post: 7th May 2007, 22:32
