Results 1 to 18 of 18
    May 2008
    Whenever I open my script ex-DirectShowSource("C:\Documents and Settings\KD\Desktop\BLEACH - 166 RAW.mkv") in virtualdub it gives me this error ex-
    "error during script execution at line 1, column 17: Variable 'DirectShowSource' not found
    DirectShowSource<!>("C:\Documents and Settings\KD\Desktop\BLEACH - 166 RAW.mkv")
  2. Member Soopafresh's Avatar
    Jan 2004
    Reinstall Avisynth
    USA
    ineedhelp123, Do not post the same topic on several forums.
    Please do not cross post, once is enough. The duplicate has been deleted.
    In the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
    Try to choose a subject that describes your topic.
    Please do not use topic subjects like Help me!!! or Problems.
    Thanks,
    Moderator redwudz
    May 2008
    I re-installed it and my problem went away..but a new one arose.
    Now it says "Error!:Statsfile not found" and after i click ok it shows another error "Virtualdub Error:Cannot start video compression- The operation is not supported.(error code -1)".....What can I do to fix this problem? Its so frustrating, all I want to do is convert an mkv file
  5. Either you're trying to run the 2nd pass without first having run the first pass, or you didn't set a name and destination for the stats file.
    May 2008
    Yay, I got it to work thanks to manono but Virtualdub crashed so i tryed again but still no success
    it shows this error whenever it crashes "An out-of-bounds memory access (access violation) occurred in module 'libavcodec'...
    ...reading address 00000000.
    May 2008
    May 2008
    Can I do something to fix this problem?........
    May 2008
    Please! Can someone reply on how to fix this, its quite frustrating.
  10. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    what gspot report about the original? from the file name it might be some sort of transport stream and not a program stream.
    May 2008
    Gspot? What is that.... Its an mkv file with a h.264 stream and an aac stream but VirtualDub crashes when i try to save it as an avi
    VDub sometimes has problems with *.mkv's, try something like alltoavi and convert to Xvid or DivX
    May 2008
    So there's no way to fix this besides switching to a different converter?...God Damnit!!
    May 2008
    -bump- I still need help, does anyone know how to fix my VIRTUALDUB problem?
  15. If you're using AviSynth to open your MKV file then VirtualDub isn't the problem. There is a problem in your DirectShow MKV file splitter or the codec that's decoding the video (ffdshow?).
    In my experience, MKV is mostly a write only format. It can be very difficult to convert to anything else.
    May 2008
    If its its the mkv splitter how can i fix this?
  17. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Re-install the splitter components or update them to the latest versions
    Read my blog here.
  18. Your h.264 stream may be using PAFF and MBAFF which older versions of ffdshow didn't support. Update ffdshow if you haven't already. Or get CoreAVC.
