Hi to All. I am using Wax to create animated 3D titles. Wax creates an avi as a result. Then I use this avi in my video project. If I create a single colour text and have it rotated around the vertical axis the resulting clip is OK. But if I create a text with different front, back and side colours and keep the same animation the resulting clip is jerky. The frame rate (25) and other parameters are the same. Is the problem coming from using multiple colours which the program has to update as the animation continues? What can I do to overcome this problem?My computer configuration is quite powerful. Any suggestions?
				Results 1 to 1 of 1
  Using mencoder to join mpeg video result in a/v out of sync.By Jemore in forum EditingReplies: 3Last Post: 18th Jan 2012, 03:02
  Debugmode Wax: Can't preview or render imported video clipsBy Sean O'Scare in forum EditingReplies: 0Last Post: 30th Oct 2011, 10:17
  how to create Animated titleBy akakiami in forum Authoring (DVD)Replies: 10Last Post: 16th Oct 2008, 17:22
  Instant Handbrake: Video size result?By Jeikobu in forum MacReplies: 5Last Post: 17th Jun 2008, 22:14
  DivX to DVD with FFMpegX - result jerkyBy akulier in forum ffmpegX general discussionReplies: 5Last Post: 19th Feb 2008, 17:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
