I have an EAC installed. I want to backup an audio CD - don't need the songs on my drive. What's the best procedure? Thank you!
are you looking to make a copy of the cd? cd->cd?
I sorted it out. Two ways: once making a cue and single wav file and then dropping the cue into EAC and burning a CD-R and once ripping each track and writing a new audio CD with EAC - both work. I'm sure there are other ways. Is there a way to just make a disc image? Just curious. I have simply never made audio CDs before, if you can believe it. Thank you!
Some possible problems I'm Having with EAC . . .
By Seeker47 in forum AudioReplies: 4Last Post: 6th Dec 2011, 10:47 -
EAC + lame.exe: sometimes there is 32 kBit/s, sometimes not in command line
By flashandpan007 in forum AudioReplies: 5Last Post: 13th May 2011, 11:36 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
Camcorder Tutorial??
By Ray & Paula in forum Newbie / General discussionsReplies: 1Last Post: 26th Mar 2008, 12:42 -
Does EAC remove Copy Protection from CDs ?
By Seeker47 in forum AudioReplies: 4Last Post: 15th Jun 2007, 18:49
