Hi forum, I just had some questions about audio and fps.
Question 1
My encoder of choice is CCE. The knowledgable folks on this forum taught me how to use CCE, AviSynth and DGPulldown to convert non-standard framerate video to NTSC compliant DVD files.
When I was taught this, I was still encoding both the audio and video in CCE. However, the same people here told me that I should always disable the audio in CCE, as it is a video encoder and let an audio program handle the audio. This was great advice because CCE rarely crashes now that I do that.
Say I have a video with these specs:
Video fps = 20.00
If I use CCE and Avisynth (script is at the end of this post) to convert the video to NTSC compliant, can I use a program like FFMPeg (my audio encoder of choice) or some other command line utility to convert the audio to the same frame rate?
Below is the script someone from here gave me a while back to use for non-standard fps:
<SCRIPT>
AVISource("C:\mymovie.avi")
LanczosResize(640,336,0,3,592,454)
AddBorders(40,72,40,72)
ChangeFPS(59.94)
SeparateFields()
SelectEvery(4, 0, 3)
Weave()
ConvertToYUY2()
</SCRIPT>
Question 2
I have an AVI file that is 59.94 fps. Would I still have to use the methods discussed above, or is 59.94 NTSC compliant. I know 59.94 is a special fps, I just don't know its actually meaning.
Results 1 to 17 of 17
Audio doesn't have a framerate, just length to determine it's playback time. Check the length of your converted video file and your audio file. If they match, then you just need a format for the audio. If they differ, you can stretch or compress the audio length with a audio editor like Audacity to change it. If the change isn't too much, you may not have to adjust the pitch, but Audacity can do that also.
Someone else may be able to give you help with your 59.94fps video. But what format is it in? What codec is it using? -
Hi.
59.94/2 = 29.97.
Sure to be NTSC
Open it in http://mediainfo.sourceforge.net/en. Change to View/Text. Cut and past the text in a post.
Glad to have a look at it.
I decided to go ahead and encode the audio and video together in CCE and be done with itOriginally Posted by pcspeak
. However, I am going to post the information because I would really be in trouble if the files were MP4s as CCE has alot of trouble handling audio in that format:
<MEDIAINFO>
General #0
Complete name : C:\mymovie\myvideo.avi
Format : AVI
Format/Family : RIFF
File size : 215 MiB
PlayTime : 23mn 54s
Bit rate : 1257 Kbps
StreamSize : 4.03 MiB
Writing library : VirtualDub build 23350/release
Comment : CRC32F03A683F3
Video #0
Codec : XviD
Codec/Family : MPEG-4V
Codec/Info : XviD project
Codec profile : Streaming Video Profile/Level 1
Codec settings, Packet bitst : Yes
Codec settings, BVOP : Yes
Codec settings, QPel : No
Codec settings, GMC : 3
Codec settings, Matrix : Default
PlayTime : 23mn 54s
Bit rate : 1041 Kbps
Width : 704 pixels
Height : 396 pixels
Display Aspect ratio : 16/9
Frame rate : 59.959 fps
Resolution : 8 bits
Chroma : 4:2:0
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.062
StreamSize : 178 MiB
Audio #0
Codec : MPEG-1 Audio layer 3
PlayTime : 23mn 54s
Bit rate mode : CBR
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48 KHz
Resolution : 16 bits
Video0 delay : 24ms
StreamSize : 32.8 MiB
Writing library : Gogo (after 3.0)
</MEDIAINFO> -
The script you gave should work. You don't need the ChangeFPS() command since the video is already 59.94 fps.
Your 20 fps video could be encoded at 20 fps progressive MPEG2 and then have pulldown flags added with DGPulldown. That would give better quality.
None of what you are doing changes the running time of the video so there's no need to adjust the audio. -
Right, except no encoder I know of will actually encode for 20fps. When I have silent films at 19.98fps, I encode for 23.976fps and then run the result through DGPulldown set for 19.98->29.97fps.Your 20 fps video could be encoded at 20 fps progressive MPEG2 and then have pulldown flags added with DGPulldown.
I also raise all my bitrates by a factor of 23.976/19.98=1.2 so the sizes and max/min bitrates come out correct. And, as you say, since the lengths remain the same no audio stretching has to be done. -
You're right. I keep forgetting that MPEG only allows certain frame rates. And 20 fps isn't one of them.Originally Posted by manono
Jagabo, yes it does work and yes, I removed the ChangeFPS, but what I am trying to figure out is how I would accomplish the conversion if I wanted to encode the audio and video separately.Originally Posted by jagabo
I personally do not like using CCE to encode the audio. -
Load the avs script into virtualdub and save a WAV file
Read my blog here.
In Virtualdub there is a Save WAV option under the File menu.
Read my blog here.
If you Save WAV from VirtualDub in Audio -> Direct Stream Copy mode and your audio is compressed you will end up with a WAV file of compressed audio. A WAV file with MP3 compressed audio, for example. If you enable Audio -> Full Processing mode you will end up with uncompressed audio.
If you use VirtualDubMod you can demux the audio into its native container, MP2, MP3, AC3, etc. Streams -> Stream List -> Demux -
Sorry, I forgot he was using an AviSynth script. Yes, the audio would be uncompressed in that case because AviSynth will feed uncompressed audio to VirtualDub.Originally Posted by guns1inger
Thanks fellas.
Also, is there a way I can do this using a command line utility? -
With these installed. Or later versions.
BeSweetv1.5b31.zip
http://kurtnoise.free.fr/index.php?dir=BeLight/&file=bsn_20070513.zip -> bsn.dll copied into the BeSweet folder
aften-svn-r683-icl10_1-win32-bin.zip -> aften.exe copied into the BeSweet folder
All of the following will work. Code go on a single line. No wordwrap. Change path names to reflect your program locations. I save as Avcd.cmd, Amp3.cmd & Aac3.cmd. Reminds me that the command file only deals with the audio.
Extract audio from an AVI and output as mpg @ 44100. Used for creating a VCD.
Extract audio from an AVI and output as AC3Code:"C:\VidAud\Besweet\BeSweet.exe" -core( -input "video.avi" -output "audio.mp3" ) -ota( ) -ssrc( --rate 44100 ) -toolame( -m s -b 128 )
Extract audio from an AVI and output as MP3.Code:"C:\VidAud\Besweet\BeSweet.exe" -core( -input "video.avi" -output "audio.ac3" ) -ota( ) -ssrc( --rate 48000 ) -bsn( -exe aften.exe -b 224 )
Code:"C:\VidAud\Besweet\BeSweet.exe" -core( -input "video.avi" -output "audio.mp3" ) -lame( -b 192 )
Thanks for the response. I will look into this.Originally Posted by pcspeak
Videos with different framerates need to be joined together
By vertigoelectric in forum Video ConversionReplies: 15Last Post: 18th Mar 2012, 04:21 -
Need some education on Audio formats used in DVD's (standard and Bluray)
By nzdreamer55 in forum Newbie / General discussionsReplies: 10Last Post: 7th Apr 2011, 22:09 -
Standard Def DVD Movies With Best Picture Quality?
By avkhatri in forum Off topicReplies: 2Last Post: 8th Jul 2009, 18:29 -
Synchronize audio and video with different framerates
By dexter30 in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2008, 15:53 -
Non-Standard Frame Rates, Demuxed Audio and FFMpeg
By Maikeru-sama in forum Video ConversionReplies: 1Last Post: 12th Jan 2008, 12:24
