Hi,
Apologies if this is not the right way to ask for help using this tool.
The tool says it's possible to add multiple AVI files at once to be subtitled, but this goes against the instruction where the AVI file and the SRT file must have the same name! So if I have a movie file split into two files, commonly 750-ish MB each, for example movie1.avi and movie2.avi, how am I supposed to get this to work, when the SRT file needs to be named the same as the movie file, but if there's more than one movie file...???
I'm sure it's something simple, would be very grateful if someone could clarify this for me.
Thanks!
DivxMuxGui provides a "join mode". I'm not so sure that's what you need but at least you should try.
aviaddxsubs problem need help
By higina in forum SubtitleReplies: 9Last Post: 14th Aug 2021, 12:28 -
subtitle position with aviaddxsubs
By marioval in forum SubtitleReplies: 3Last Post: 27th Feb 2011, 19:15 -
AVIAddXSubs Question: PS3 can't read Japanese Subs
By NikoNikoNeko in forum SubtitleReplies: 3Last Post: 20th Oct 2010, 21:21 -
AVIAddXSubs matroska support?
By therock003 in forum SubtitleReplies: 9Last Post: 3rd Mar 2010, 08:21 -
AVIAddXSubs advice needed
By betalb2008 in forum SubtitleReplies: 4Last Post: 25th Jul 2009, 19:55
