Hi, for some reason my pc which used to have USB 2.0 has now only got 1.1 (every time I plug my camera into a port it tells me to use a high speed port)
Now I've seen those USB hubs you plug into your PC to expand the amount of ports and they say it's backwards compatable with 1.1, but does that mean I will get 2.0 out of the ports or just 1.1?
1.1Originally Posted by guitardan
You need to fix your port driver or buy a USB2.0 pci card.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
If you truly had USB 2.0 support before, something has gone wrong.Originally Posted by guitardan
Reinstall or update your motherboard and chipset drivers and firmware. That should re-establish USB 2.0.
If not, a USB 2.0 card is a pretty inexpensive option. -
Look in your 'Device Manager">Universal Serial Bus Controllers'. You should see something similar to a 'Standard Enhanced' controller. That's a USB 2.0 controller. You can uninstall or update them there. If you uninstall, then reboot, it might reset it. But if all else fails, a USB 2.0 PCI card is fairly cheap.
What Software is Compatable with X.V. Color?
By Jake Bernhard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 4th Mar 2011, 22:15 -
Backwards running
By Zenner in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 09:41 -
WD player (can it play backwards ?) recertified ?
By Umen Pich in forum Media Center PC / MediaCentersReplies: 1Last Post: 3rd Jun 2010, 06:59 -
Is QT Alternative 1.81 and 3.x compatable with Windows Vista SP2?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 8th Feb 2010, 00:02 -
Gui for dvdauthor ERR: SCR moves backwards from...
By lienny in forum Authoring (DVD)Replies: 35Last Post: 24th Feb 2009, 05:18
