    Jan 2004
    Queens
    ok some help please. I saw today on my c: drive a folder named a2cbe8031da6333b2e86bf. I use dvdfab and anydvd is this part of it. Don't dare to delete it unless someone knows.
    Oct 2005
    666th portal
    what's in it?
    USA
    It could just be a temp folder left over from an program install. Most any computer has a few of them at the root of the boot drive, some empty. MS leaves them there fairly often. If it's been there a while, you can usually delete it.
  4. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Agreed. I say nuke it. Nuke it out of principle!
  5. Windows update sometimes uses folders like that.
  6. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    To second what aedipuss said - what files are in the folder?
  7. Member bendixG15's Avatar
    Aug 2004
    I got a few like this ..
    {8FFBE65D-2C9C-4669-84BD-5829DC0B603C}
    Its listed as an active X control from some downloaded file.
  8. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    First of all I would virus scan them before opening, copy to different media and delete. If no problem that's it.
