I have a home movie PAL VHS and would like to convert it into the NTSC VHS or DVD because I only have NTSC video players and TV. Does anyone know the equipments in the USA and method that enable for me to complete the conversion project?
Results 1 to 10 of 10
you would probably need to buy a pal vhs machine that will run on 60HZ u.s. power.
if it were mine and i didn't have the equipment to play it and it was important i'd send to to a video shop that did, and have it converted to dvd.--
First of all you need a VHS VCR that can actually play back the PAL VHS video tape that you have. You basically have one of two choices. You can buy a special VHS VCR that can play both NTSC VHS and PAL VHS but the choice is this: most models are made to output only what they are playing ... in other words play a PAL VHS video tape and get a PAL video signal on output ... whereas some can actually do conversion ... in other words play a PAL VHS video tape and you can get a PAL video signal on output or a NTSC video signal on output.
The problem here is that the type that do the conversion are very expensive and the one that was most popular is now very hard if not impossible to find ... which pretty much means you are "stuck" with buying a non-conversion model.
There are several on-line websites that sell such equipment. Just do a google search for "multisystem" or "multi-system" etc.
However there is one in particular that I am fond of because I know they are reliable and cheap: 220-Electronics.com
Another site that seems popular and from which I've purchased from myself: World-Import.com
The Samsung SV-5000 is a multi-system VHS VCR that does conversion. Supposedly it is very hard to find these days but currently 220-Electronics.com claim that they have it in stock at $469.00 US Dollars + shipping. Pop in a PAL VHS video tape and it will output PAL or NTSC as per your selection. Easy-to-use and from my understanding the quality is very good. Not cheap though.
You can get away much cheaper with the non-converting type of multi-system VHS VCR. For instance 220-Electronics.com has a 6-Head Hi-Fi Stereo SHARP for $239.99 ... they have a 6-Head Hi-Fi Stereo PANASONCI for $239.99 ... they have a 6-Head Hi-Fi Stereo SONY for $179.00
Only problem is ... while cheaper ... they will only output PAL when playing back a PAL VHS video tape. So what do you do?
1.) Record to a stand alone DVD recorder that can record PAL
2.) Record to a computer capture device that can capture in PAL
Now at this point you have yet another option ... you can make a PAL DVD and play it back on a DVD player that does PAL to NTSC on-the-fly of which there are big enough (some very inexpensive) choices. The other option is to convert to NTSC on a computer BUT that can be very complicated to do just right.
However you slice it ... not cheap. Not cheap at all.
If you only have like one or two tapes and don't expect getting any more then you might want to just ship the tape off to a place that does conversion. Many places on-line offer this and you may even find a local place that does it if you look in the yellow pages under VIDEO SERVICES etc.
Generally speaking such a service should cost you no more than $20 - $30 US Dollars per video tape.
- John "FulciLives" Coleman
P.S.
I forgot to mention yet another option. There are video convert boxes that exist that will do conversion. So if you buy one of the non-converter type multi-system VHS VCR units you can plug the output into a converter box that will convert it to NTSC. Problem with this is that said converter boxes are expensive so by the time you buy the multi-system VHS VCR and the converter box ... you might as well just buy the all-in-one Samsung SV-5000 which supposedly does a better job that most of those stand alone converter boxes anyways."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
It's pretty straight forward if you have a PAL VCR. I converted my PAL "Song of the South" VHS to NTSC DVD and it was easy. The two big hurdles were choosing which PAL VCR, and setting up Virtual VCR to capture the correct PAL mode.
https://forum.videohelp.com/topic314195.html#1609497
Darryl -
I am assuming you only have 1 tape to convert. Given the cost of buying any VCR in the USA capable of playing or converting a PAL signal, is it REALLY worth spending $200 or much much more just to get the VCR part of it to do it yourself? Many American cities have small video shops that specialize in converting video tapes to DVD for customers and they probably have the necessary equipment to do the format conversion for you. I think there are also places that advertise on the internet to do this kind of conversion to. Really, pay someone to do it if it's just a one tape conversion. It's not worth the money to buy everything necessary to do it one time yourself.
Yeah, except the small video shops won't do it right. Plus, this is our hobby.
Darryl -
We have a Hitachi Multisystem VHS player and TV. We can see Song of the South but can't copy it to American NTSC VHS recorder. Any suggestions?
http://www.kiva.org/about -
How do I capture it to computer? We got our Multisystem at a second hand store for about $20. Did have to buy the Multisystem TV and have it shipped.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
PAL-N VHS to ntsc dvd
By Paul99 in forum Video ConversionReplies: 17Last Post: 4th Apr 2011, 16:32 -
Convert PAL to NTSC VHS?
By manhnt in forum Newbie / General discussionsReplies: 4Last Post: 29th Jul 2009, 14:49 -
Newbie needs to convert NTSC VHS tapes to PAL DVD
By mcullen8320 in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2008, 13:51 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 01:16
