I'm trying to match audio levels of 2 different videos (after demuxing and boosting one of them): one has mpeg1, the other has ac3. The problem is they sound the same in PC, but the mpeg1 is louder on the TV. I've tried different software to preview them, but the levels sound the same. Any suggestions how I can get an accurate rendition?
Results 1 to 10 of 10
The AC3 decoder you are using on the computer is probably set up to increase the volume by 10 or 20 dB. Go to its setup applet and adjust it.
I have AC3Filter but uninstalled it awhile back when I was setting up Belight. I thought the AC3 filter for Nero Wave editor was controlling things, but when I set its 5.1 output to 0 gain, the AC3 sounds even louder.
I have FFdShow installed, but it's AC3 Decoder doesn't have anything checked off to interact. I'll try uninstalling that and see if anything good happens. -
The problem stems from the fact that AC3 audio is normally encoded 10 or 20 dB below most computer audio files. So some AC3 decoders automatically (or manually) boost the audio levels.
yeah, that's the first thing I tried (both under Filters, and Audio-Options).
I also tried adjusting the Dvd player (the standalone, not PC software) audio settings, but nothing changed. -
I noticed that different volume AC3 always plays at the same level in CMP, VLC and DvdShrink, regardless of the real level. TDA, Mpeg2Schnitt (when audio is demuxed), and Windows Media Player will play the actual level. How can I adjust the first 3 wares to play accurately - or can't they do this? I tried customizing their settings but no luck. They must happen to use the same default audio decoders which normalizes whatever audio to the same level (I tried switching decoders in CMP but no luck).
How to convert 5 ch. AC3 to 5 ch. MPEG-2 Layer II
By macman241 in forum AudioReplies: 21Last Post: 1st Sep 2016, 11:08 -
Vista compatible mpeg joiner where 2 clips have diff dimensions?
By wetcamelfood in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2009, 13:14 -
diff. btw ac3, divx, ffdshow codecs???
By geronemo in forum Video ConversionReplies: 0Last Post: 18th Nov 2007, 15:25 -
How do i convert MPEG audio to ac3?
By php111 in forum AudioReplies: 9Last Post: 28th Sep 2007, 16:13 -
MPEG-2 With AC3 Sound on DVD
By crazynewfie in forum Newbie / General discussionsReplies: 2Last Post: 16th Sep 2007, 12:53
