Right ....I had a problem where upon bootup I recieved an error message saying
windows cannot find iexplore.exe
and it then launched two browser windows when I closed the error message window down.
I installed startup cop and disabled two instances of iexplore and two instances of default browser and got rid of the two windows that were opening but still had the error message.
I then decided that if windows couldn't find iexplore.exe then I would help it and copied and pasted the executable from the internet explorer folder into my windows folder.
SORTED.
No more error message.
But now I have a default browser opening up when I boot the computer and it is not listed in startup cop..........
I am using winME / IE6
It's nothing catastrophic by any means and it just means that I have to close the browser down if I just want the desktop but it's really annoying.
By the way this was off a format and clean install with I.E 5.5 then the problem cropped up as soon as it was installed so I went and did the misrosoft upgrade to I.E 6 and the problem is still there.
Any ideas...
Results 1 to 1 of 1
Internet Explorer 7 tabs problem
By Nintendo Fan in forum ComputerReplies: 4Last Post: 25th Feb 2010, 18:41 -
Internet Explorer 8 Keep Crashing
By Squid_uk in forum Newbie / General discussionsReplies: 6Last Post: 27th Oct 2009, 17:44 -
Internet Explorer 6 problem on Windows 2000
By edong in forum ComputerReplies: 17Last Post: 23rd May 2008, 00:04 -
something wrong with internet explorer
By ssaamm in forum Newbie / General discussionsReplies: 9Last Post: 5th Oct 2007, 07:28 -
How can you get rid of Internet Explorer?
By video_enthusiast07 in forum ComputerReplies: 8Last Post: 10th Jun 2007, 18:05
