Hi Everyone,
Here's my problem.
After compressing a .mov file (2GIG) using the following modified preset in Sorenson Squeeze:
.flv VP6_768K_Stream
Frame size: 640x480
Display Aspect Ration Policy: Letter Box
Drop Frames to Maintain Data Rate: 90
My resulted .flv file's audio and video, when added in a flash file as a new (Actionscript-controlled) video, is not well synchronized.
Its starts synchronized and a few seconds after, the audio is unsynchronized from the video.
This happens when I play the flash file locally, its not even on a web server yet.
If it helps understand my problem:
The original .mov file was generated from an After effects edit I made. I compressed it into a .mov file using the Add to Render Queue, using the Animation preset for the Video Format. I made sure to keep the same fps setting at Medium quality.
But again, this issue does not happen to my original .mov file.
Did anyone encounter that issue when compressing a .mov file into a VP6 flv at 768k stream ? If so, do you know of a way to compress it so that sound and video always stay in sync?
I am using a MacBook Pro 15.4inch
Sorenson Squeeze 4.5.3
Flash CS3
Would appreciate any help possible.
Thanks.
Patrick
Results 1 to 9 of 9
PSAAD.COM
The issue is probably tied to the 90 frames dropped in order to mainatain the data
or try a higher bitrate.
There's 768K Stream, which is the choice I took.
There's Total Data Rate: set by default to 661
There's Data Rate: set by default to 615
Also, the keyframe is set at each 45 frames
Does the bitrate correspond to any of these ?
Pat.PSAAD.COM -
I looked into the .mov file's Quicktime Movie Inspector and it says:
Code:Data Rate: 73.10 mbits/s Apple Format: Apple Animation, 640 x 480, Millions 16-bit Integer (Big Endian), Stereo, 44.100 kHz FPS: 29.97 Data Size: 3.34 GB
I can specify a Total Data Rate different then the default one, and I can also modify the Data Rate as well. What would be a good balance?
Again,
I looked up another forum and the user says that the issue lies with sorenson squeeze which just can't seem to handle keeping the audio on On2 VP6 codec. but then again, that wouldn't make sense that a software so powerful can't handle this simple task of syncing audio with video.
Flash video clips in sync lacks the ability to add watermarks to encoded videosPSAAD.COM -
Filesize = bitrate x running time. Universal rule of video compression.
In other words, make the bitrate higher, the file size will increase. Reduce the bitrate, you get a smaller file, but at some point you start to sacrifice quality. You cannot have a high bitrate and a small file without reducing the length of the video.
I can't really offer you any further help, other than to suggest perhaps you try an different encoder.Read my blog here.
Thanks for your help guns1inger, I will give it another shot with a much higher bitrate ... see if I can fix my issue this time.
Regards,
Patrick from MontrealPSAAD.COM -
Originally Posted by psaad
I just noticed that there is a different datarate for the audio that is used for compression:
By default for the audio: compressed to:
Fraunhofer MP3
Data Rate: 48kbps
if the datarate, in this case, is different then the video could that cause an out of sync ?PSAAD.COM -
It seems the problem lies with Sorenson Squeeze 4.5.3...as I said earlier, the out of sync problem does not occur in Sorenson Squeeze 5(trial version)
I found a version of Adobe CS3 Flash Encoder and used it to compress it to 700kbs OnVP6 and it worked like a charmPSAAD.COM
Sorenson Squeeze 5.0 and QT
By rotuts in forum MacReplies: 3Last Post: 9th Dec 2010, 15:41 -
Converting 16x9 video to 4x3 letterboxed in Sorenson Squeeze
By pjbarbour in forum Video ConversionReplies: 0Last Post: 10th Mar 2010, 09:49 -
Sorenson Squeeze
By kr236rk in forum Video ConversionReplies: 36Last Post: 27th Oct 2008, 07:50 -
H264 Compression Sorenson Squeeze... HELP!
By DWTV in forum Video ConversionReplies: 8Last Post: 27th Jul 2007, 15:36 -
Sorenson Squeeze 4.5?
By jupiter84 in forum MacReplies: 1Last Post: 9th May 2007, 01:46
