I tried to add subtitles using the guide.
Everything runs fine with VirtualDub, but I got an Illegal Floating Error with TMPGEnc when I try to frameserve and encode to MPG.
Is the VBR audio from the avi file the trouble here ?
Probably it is. First decompress the the audio to wav with VirtualDub.
I was right. You can't frameserve with VBR Audio. Now it works perfectly.
I'm also having trouble frameserving to TMPG--did you select "no audio" in VirtualDub before frameserving, and use the extracted WAV as audio source in TMPG??Originally Posted by Elesias
thanks
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
Subrip doesn't work
By mtc in forum SubtitleReplies: 7Last Post: 1st Feb 2009, 22:54 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58 -
SmallDVD doesn't work
By dnix71 in forum MacReplies: 10Last Post: 29th Aug 2007, 01:47 -
Newbie: Why doesn't it work?
By orchestr in forum ffmpegX general discussionReplies: 8Last Post: 24th May 2007, 12:30
