Results 1 to 10 of 10
    May 2006
    MPAA sues Alleged File-Sharers: form www.homemediamagazine.com
    Here we go. Five people in Ohio have been sued for downloading movies on BitComet, KaZaA and iMesh.
    The RIAA sued 30,000 music downloader's. Are you afraid?
  2. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Nope!!
    Because i don't use lame programs like those, or limewire, ect ect ect...
    Only idiot noobs do
    You should put a more direct link... i know i spent all of 20 seconds looking at the front page and don't care enough to actually search for the specific article 8)
    Although i did notice this stupidity....
    Flexplay to Distribute Disposable Movies at Staples
    Posted: May 21, 2008
    Flexplay Technologies Inc. May 21 said it would start selling disposable movie DVDs at nearly 2,000 Staples Inc. stores beginning in June.
  3. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    why do people still use that crap....duh
    'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
    It's much easier to just download the Youtube music video.
    Or play it, while your sound card records the stereo mix.
    In the end, seriously, $1 on iTunes. So easy, so cheap. Why not?
  5. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Because I can go buy a refurbished used CD for $4.Guranteed to play and not skip. Rip it and put it away in its case. My brother has amassed quite a collection doing this. I'm getting to the age now I don't buy music anymore anyhow. I have everything I want...
  6. a lot of issues most audiophiles have with itunes and the like is the bitrate, quality and format used on the files provided.
    you give me a 320 mp3 , sure I will be there. You give me an mp3 at 192 or less or wma format, no thanks
  7. Banned
    Jun 2004
    Bah!!
    I'll never pay for an mp3 or any other lossy format at any bitrate.....
    If i'm gonna pay $1.00 a song i'll either buy the original used, like thecoalman or at a store brand new if i can't find it used, and make my own mp3 if i want one and still have the original cd 8)
  8. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    I can't tell much difference between 192 or 128 or WMA or MP3... couse my ears probably aren't in the best shape...
    Having said that can MP3 do this? 20kbps mono :P : www.40lbhead.com/headradio/wma/shoulders_of_fate.wma
    I've read few comparison between MP3 and WMA, most came to the conclusion they were pretty close at higher bitrates however once you get into really low bitrates WMA leaves MP3 in the dust. Only really suitable for application such as where that file is used, its made for a streaming "radio". 56k user can still listen and surf... and its really not that bad.
    Here's another: www.40lbhead.com/headradio/wma/climb_high_enough.wma
    You might notice a lot of distortion using a bitrate like that when you get a lot of high pitched sounds, cymbals and the snare drum seem to cause it a lot.
  9. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Used CD shops are AWESOME and my preferred shopping choice but quite a few people live in the "boonies" where a shop like that is hard to find.
