Hi all, sorry for the obscure title, but couldn't find a brief way of saying this, so here goes. I have "successfully" authored a DVD from a DivX source file, using DVDFlick to author the DVD folder structure, then Nero 8 to burn the Video DVD. I find I can insert the DVD OK in to my standalone Phillips DVD player, which is attached to my TV. The DVD does autoplay quite successfully, as I have not asked for it to have a menu or anything like that. So, it plays out fine. But when I press Stop/Pause or anything else on my Phillips Remote Control, I get a problem: nothing happens, no response, as if the DVD is somehow not recognising the commands. All I can do is eject the DVD in order to "Stop" it. Nb., this does not happen with other DVDs as standard, only the one I have authored. Any thoughts on what I am doing wrong, and how I could corrrect this issue?
Best Wishes,
Paul -
It could be authored with user restrictions but I doubt that dvd flick does that. I would try an other all-in-one converter like favc(free) or convertxtodvd.
Hi, thanks Baldrick, will try those. Was wondering, could it be because I burnt it to a Re-Writable? Or would that be nothing to do with it?
Best Wishes,
Paul -
Stop and Pause have not much to do with DVD, it is a player which will respond to those.
Did you check a battery in your remount, it could be too week to produce strong enough signal for player to see.
To be sure, just try buttons on the player itself.
HELP - Lost Remote Control for DVD Player
By Jezza82 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 16th Feb 2013, 19:17 -
Remote Control Problem with new Sony SR500H DVD player
By Bass Cadet in forum Newbie / General discussionsReplies: 3Last Post: 27th Jun 2011, 12:56 -
Need Remote control code for Desay DEVD player 5701 bought at Radio Shack
By PunkMaister in forum DVD & Blu-ray PlayersReplies: 0Last Post: 15th Aug 2009, 19:20 -
Standalone Divx/Xvid player with remote & usb
By bxr510 in forum Media Center PC / MediaCentersReplies: 5Last Post: 19th Aug 2008, 06:19 -
Is no remote control DVD player hackable?
By coody in forum DVD & Blu-ray PlayersReplies: 3Last Post: 22nd Feb 2008, 10:08
