Results 1 to 14 of 14
    May 2008
    Hey Everyone.
    I have a PC and I'm trying to find a software that makes it easy to setup a DVD to autoplay when you stick it in the DVD Player.
    Right now, I'm using Nero 8 trial version and I can't seem to find that option. I'm also trying out Movie Edit Pro 14 trial version and I think it autoplays when I select "No menus" under the advanced setting.
    If anyone has any reccomendations for DVD burning software that's easy to use, and does'nt cost a ton and produces good quality DVD's please let me know!
    Oct 2005
    666th portal
    it's not the burning software that sets the autoplay. it needs to be set by the authoring software. try convertxtodvd, in the options there is a place to check autoplay. it can also be set after authoring by using any software that accesses the ifo files like ifoedit or pgcedit.
    May 2008
    Thanks again Aedi.
    Where do I find out if my software can access those ifo files? ANd how do I access them? ConvertX does appear to be a very easy tool to use....can I get it at retail stores or only online?
    Oct 2005
    666th portal
    probably just online.
    you need to set the authoring software to write the video files to your hard drive and not to burn them. then you can change the dvd's ifo files before writing it to disc.
    ifoedit and pgcedit are free. download them and give them a whirl.
    Oct 2006
    Canada
    Autoplay function is part of Windows set up, if you are talking about PC player.
    Just click properties for your drive, than open AutoPlay, in there choose a player software and click Select the action to perfom-Applay. Done
    Mar 2008
    Seattle, WA
    I have been using Roxio Easy Media Creator 9 to edit my DV files, but I wasn't happy with the results when I burned a DVD. The audio/video were out of sync by about 200 mS, and also the motion looked very jumpy and not smooth.
    I decided to try using Adobe Premiere Elements 4 which I had bought about 3 months ago. I just imported the 35 minute movie as digital video into the program and then burned a DVD using the same screen on Abode. The result was very impressive. No DVD menu, the DVD started automatically, the video was great as well as the audio and the video and audio were synced perfectly. Even though I don't like this software for editing, it does do a great job on authoring DVD's.
    I'm sure I could set it up to do a into and menus with the DVD, but right now I just want to go simple.
    Do any of you hot shots think you could remove the telephone wires from this pic for me? It's way beyond my ability, and I don't even know if it can be done. I've never used photoshop, but I would think it would be really tough doing it through the sign. If you would like to try, I'd sure be happy to email you the picture. Thanks.
    Apr 2004
    Miskatonic U
    10 minutes in photoshop. Post it somewhere and PM me a link
    Read my blog here.
    Mar 2008
    Seattle, WA
    Thanks, it looks great! Now you can see how much my printer is off by comparing the 1st pic with the 2nd. I'm sure the printed label will look just fine for this "free" project. Thanks again.
    Mar 2008
    Seattle, WA
    Actually the camera lightened up the first picture so the printed picture is actually darker than it appears.
    Sorry to add another post, but I got several error messages when I tried to edit my post above.
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You are printing directly onto the disc, and not using labels - aren't you ?
    Read my blog here.
    Mar 2008
    Seattle, WA
    No, those are Avery labels I'm using.
  12. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Not a big fan of labels. The tolerance for DVDs is much lower than CDs, so even small balance problem can throw off reading the disc correctly. Also, DVDs tend to get hotter than CDs for longer periods, causing the labels to bubble and lift from the disc, which also leads to playback issues and even discs getting caught in drives. Do a search of the forums and you will find many tales from people who thought their precious discs were ruined because they would not play, only to find that once they removed the labels they had put on when they burned them, playback returned to normal.
    Labels on CDs : OK, but not ideal. Labels on DVD : asking for trouble in the long run.
    Read my blog here.
    Oct 2006
    Canada
    I do have a little different view on labels. I have been using them on CD for 6+ years and DVD about 4+, so far no problem with any of them playing.
    Mar 2008
    Seattle, WA
    Well you may be right. But, I distributed about 100 VHS tapes between 1989 and 1993 to all my church friends. They were highlights of social gatherings, events and of course many beautiful women--this is the DFW area of Texas after all. We were mostly signle back then. I managed to keep all the VHS masters over the years but I'll bet almost none of the 30 or 35 people I recently sent video clips to had the duplicated tapes I gave them. So, I expect the same may happen with the DVDs. They will hang around the house for a few years and then disappear, but I could be wrong.
    The Avery labels are very lightweight. I just put them on with eyeball power because the alignment tool is worse than eyeballing them. I've thought about balance, but again the label is very light. So far, no one has had any trouble playing them. I'm kind of worried about the media itself. I have Memorex CDs that are 5 years old and already have that ugly yellowish tint to them, and they haven't been out in the sun.
