i purchased a toshiba 37av500u. i have hooked up my pc using a vga cable to the tv. i can see my desktop no problem, i can see streaming video from the net no problem. but when i try to play an avi, i get a blank screen. i have tried using media player classic, media player and nero showtime, all with the same result. my video card has 2 ports (1 digital ,1 analog). i am using my digital on my monitor and my analog on the tv. do i need to use the digital on my tv to watch avis? thanx for your help in advance...
Do you see the player but with just black in the video window? Then it sounds like a video overlay problem. Try then change the analog vga output to the primary monitor.
i can see the player, with black in the video window. i will try that and see what happens.
ok...now that i have switched to my primary monitor with the analog cable, i am having the same problem...does this mean i have to use my digital output on my tv for the avis to work?
What display card and display driver update do you have? It's a configuration issue but display cards each have different menus and to make it more difficult to help, menus differ by driver version.Originally Posted by goo2Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I don't have any ATI cards running here currently. The Catalyst control panel allows you to choose the primary monitor and the 9200se may support Theater Mode. Otherwise use extended desktop and try to match the Toshiba's native resolution (1366 x 768). Select the external monitor as primary (overlay).Originally Posted by goo2Recommends: Kiva.org - Loans that change lives.
How can I watch HDTV on my LCD monitor?
By TheSolidSnake in forum DVB / IPTVReplies: 6Last Post: 28th Oct 2012, 16:15 -
Best bitrate/resolution etc for watching avi on a 32/37" LCD TV
By splogo in forum DVD RippingReplies: 4Last Post: 18th Apr 2009, 08:41 -
Watching HDV footage - 1080i CRT vs. 720p LCD
By JohnnyMalaria in forum DVB / IPTVReplies: 12Last Post: 21st Feb 2008, 02:29 -
What should I be looking for in a new LCD HDTV?
By Hank Kinsley in forum DVB / IPTVReplies: 6Last Post: 18th Dec 2007, 14:19 -
Toshiba LCD
By toneystone in forum DVB / IPTVReplies: 5Last Post: 29th Nov 2007, 02:39
