  1. Is there any way to convert a .mpg file to a .dat file so i can burn it onto a vcd?
  2. There are indeed, but i suggest you follow the guides on the left. To convert an Mpg so it is vcd complient follow a guide unde the convert category and then use a guide under the Author section. You'll be needing some new software as well.
    and a tip for the future, try looking through the site before you post.
    Need a coach for anything? Try George Youngs Coaches here for the best service at the lowest prices: http://www.carlberry.co.uk/rfnshowo.asp?O=YOUNG
