Hi, I've edit one of my movies, know i want ot put it back to Dual Layer DVD.
I've haven't adjust the quality of the DVD is it's still 7.4B. So I bought a Verbatim DVD-R DL to burn it but Nero won't recognise it & Image Burn says that there is no layer break. So I've come across PGCEdit that will allow me to create a layer break. But before i can even get to that step it's gives me warning that the movie is too big, says the movie is 57GB??
Please see image attached...
Results 1 to 10 of 10
is your entire "my documents" folder being included as part of the source? it appears to be the problem to me..
I am just a worthless liar,
I am just an imbecil -
Thanks for the feedback.
ripped it with DVD Decrypter
demuxed it with DGMPGDec
converted the AC3 to Wav with HeadAC3he.
I edited the wav with Premiere Pro.
Mux it back together with ifoEdit.
and that leaves me with a VIDEO_TS without a layer break.
So I'm trying to insert one with PGCedit & burn it. Will try place the folder in my root before hand & see if it fixes the size issue. -
Hey tinker,
Shot for the heads up. I tried ImgBurn, didn't give me the choice though, just stated that there wasn't one & sugguested where one should be.
It has an feature where you can insert one but after I've done this it either says
"Cannot set layer break position when burning DVD-R DL"
or it says
"Optimal L1 Data Zone Start LBA: none found (VTS_01)
Weapon-X,Originally Posted by Weapon-X
Switch to +R DL discs; preferably Verbatim's.-The Mang -
Weapon-X,
You need to use DVD files in build mode to set the layer break,4.7GB+ files will not work properly in write mode.
I also recommend DVD+R DL. -
Thanks everyone for your responses.
I went ahead & tried to burn on my DVD-R DL risking making a coaster of it. Good news is it worked none the less, plays perfectly on my PC, must still try on a stand alone DVD player.
ripped DVD plays, but won't burn
By Yes, me in forum MacReplies: 7Last Post: 3rd Sep 2009, 04:58 -
Some Avi files will burn on dvd, others won't??????
By Qvezzy in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2009, 11:47 -
Nero won't burn video DVD
By solo_voyager in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 22:06 -
DVD burner won't finish burn
By JDShaffer in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Jul 2007, 21:41 -
DVD Won't Burn
By wwpranma in forum Video ConversionReplies: 2Last Post: 25th Jun 2007, 04:32
