Im wanting to backup my anime. what setting in dvd shrink encoding should i use for anime.... also i have clone dvd is the backup quality better in clone dvd ?
	Tick the Deep Analysis box and use the default Sharp setting. However if you have to reduce it more than 10%, seriously consider using DVD Rebuilder with HCEnc instead. Read my blog here.
	I recommend you invest in a program called DVDremakepro. It lets remove any and all excess junk on a DVD that you don't want, such as needless repeated intros/outros on episodic series discs.Originally Posted by Azures
 Another great feature is it lets you combine two or more DVDs onto a single DVD-R with menus to both intact. Which is a highly valuable feature when it comes to anime discs that only have about 3-4 episodes each. Once excess stuff is removed most of them don't even take up the whole disc, so you can take two-three and put them on a single DVD-R in Good quality.
 For the rest, DVDshrink is good enough when it comes to the final resize to fit.
  DVD Backup QuestionBy rede96 in forum Newbie / General discussionsReplies: 7Last Post: 21st Nov 2009, 17:05
  Complex Anime ripping question. Please read. TYVM! ^_^By Dratheus in forum Newbie / General discussionsReplies: 2Last Post: 5th Aug 2009, 02:52
  Anime FPS/Interlaced question...By alcOre in forum Newbie / General discussionsReplies: 6Last Post: 4th Apr 2009, 10:05
  Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 16:31
  backup questionBy rcguy1 in forum Newbie / General discussionsReplies: 3Last Post: 5th Apr 2008, 13:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
