Hey folks. I've almost got a professional looking motion menu using DLP 2. Here's what I did:
1. I created the motion menu (along with the text) using Adobe After Effects,
2. Exported the video clip from AAE,
3. Loaded the video clip into DLP 2,
4. Dragged the clip to my main menu,
5. Set up a second cell for the buttons to appear, and looped that 2nd cell.
All goes great, until I select one of the episodes. When I do that, the text and images that I created with AAE
"jumps" and blurs briefly before starting the episode. Other than that, it works great. But it really takes away from the professional menu job that I worked so hard to create.
Any ideas what's happening? Note: I did not use the render function in DLP 2. Note also: I've torn down and remade the motion menu a ton of times, and it still does the same thing.
Thanks folks!!!!
Chris
Results 1 to 1 of 1
DVD Lab Pro 2's Render Menu Motion - Intro and Loop Questions?
By xhonzi in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2009, 18:52 -
Vegas to DVD Lab Pro motion menu issues
By outerspacerace in forum Authoring (DVD)Replies: 4Last Post: 23rd Jun 2008, 21:28 -
Delayed Links, Motion Menu and DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 14Last Post: 30th Apr 2008, 02:33 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 13:03 -
how to make motion menu in dvd-lab pro that like this
By 741210 in forum Authoring (DVD)Replies: 10Last Post: 23rd Aug 2007, 23:53
