Hi,
I am trying to burn a MPG2 movie into DVD media, using TMPEGnec DVD Author 1.6. I receive an error message related the number of frames.
How can I convert the movie into standard number of frames?
I prefer to have this, using VirutaldUb converter.
Thanks,
Uriel
You need to use DGPulldown to apply 3:2/3:2 pulldown to the file so that it can be played back at 29.970 fps on standard player/TV combos.
However, g-spot is reporting this as being interlaced. DGPulldown requires progressive video, so this has been encoded incorrectly and will have to be re-done first.Read my blog here.
The original source was incorrectly made. 23.976 fps sources are supposed to be progressive. Yours is interlaced. This is what guns1inger said.
You will have to re-encode this to MPEG-2 and either set the output to 29.97 fps interlaced or set it to 23.976 fps progressive. If you encode to 23.976 fps progressive, THEN you can use DGPulldown. DGPulldown is not necessary if you encode to 29.97 fps interlaced. I'm honestly not sure which of these choices is better as your source was made incorrectly to begin with.
Bug in VirtualDub (?) -- can't cut desired number of frames
By ralf07 in forum Video ConversionReplies: 3Last Post: 21st Sep 2011, 17:50 -
Megui only processing 1/3 the number of frames
By capvid0429 in forum Video ConversionReplies: 1Last Post: 3rd Jan 2011, 19:28 -
ffmpeg Number of stream maps must match number of output streams
By tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 06:20 -
Count number of frames in AVI
By p.w in forum Video ConversionReplies: 10Last Post: 8th Mar 2010, 08:13 -
re-encode while keeping the exact number of frames
By bt04 in forum Video ConversionReplies: 16Last Post: 25th Feb 2008, 19:21
