Hi...I've been doing conversions for a long time now, but this is my first time putting videos on my phone. I can accept 3GP or MP4 and so far, the fastest method I've used is (With Super) 3GP with MPEG4 768K Video and AAC 128K Audio. I could probably reduce that to 96K, but I'd rather not. It still takes around 20 minutes for a 45 minute video. I'm trying to cut that conversion time down without loss in quality. I need at least "good" quality with 1/3 runtime for the conversion (so 15 mins for 45 min video), less conversion time and "better" quality if possible.
Any settings or software suggestions would be GREATLY appreciated. Thanks.
	Get a faster computer? Nothing affects encoding times like CPU speed. I use 3GP Converter, but have no idea how fast or slow it is, as quality is my top priority, and 15 or 20 minutes doesn't matter in the least to me...
 /Mats
	[quote](With Super) 3GP with MPEG4 768K Video and AAC 128K Audio. I could probably reduce that to 96K, but I'd rather not. It still takes around 20 minutes for a 45 minut[quote]
 768k, I thnk your way out on over kill, what is the resolution of the display, and what FPS are you using, 320*240 can give great results at under 336k video rate, and 15 fps, most phones won't even play 758k video, unless your FPS is 10 or less ? a lower bit rate will also speed up your conversion process, but memory and CPU are the main considerations for gaining speed
 check these out, these are conversion samples used to show the results of various FPS & bit rate combinations
 http://rapidshare.com/files/5119918/scrat-sample-320-240-12fps-284k.3G2
 http://rapidshare.com/files/6632834/Stargate.Atlantis.3E13.15fps-336k.MP4
 http://rapidshare.com/files/4958181/HarmonicVo320-240.3G2
 http://rapidshare.com/files/4995436/Sample-ResonantCh-25fps.3G2
 SUPER was used to make evryone of these final files
	Thank you for the suggestion. I'll try out the lower frame and bit rates. Any more suggestions are still appreciated of course
  Fastest Method to "Downcoding" a Video to 480p?By Phantoms Cry in forum Video ConversionReplies: 2Last Post: 2nd Dec 2011, 17:40
  What is the fastest MPEG-4 ASP encoder/converter for mp4 phone palyback.By muuu in forum Newbie / General discussionsReplies: 5Last Post: 12th Jan 2010, 21:53
  The fastest way for converting a DVD into AVIBy Menvedao in forum Video ConversionReplies: 3Last Post: 23rd Jul 2009, 12:06
  Convert 16:9 AVI to MP4 and resizing for mobile phone (?)By wldworld in forum Video ConversionReplies: 2Last Post: 7th Jul 2008, 00:48
  Avi conversion to support mobile phone typeBy sterankin in forum Video ConversionReplies: 7Last Post: 3rd Jul 2008, 15:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
